HRT wrote:What engine needs taking out to get timing covers off?
You must be an angry man to break a clutch like that
On the same car I also spent 6 months climbing out the drivers window as I couldnt figure out how to get the doorcard off while the door was closed, in order to fix the door release.
Alex B wrote:To be fair you're never going to fit into OS unless you hate on TS.
AE86less wrote:On the same car I also spent 6 months climbing out the drivers window as I couldnt figure out how to get the doorcard off while the door was closed, in order to fix the door release.
How do you take the door card off while the door is closed?
RedMist wrote:Probably the worst and most expensive mistake I have made so far was last month on the rally Celica. Brand new driveway laid, with an exposed agrigate, a car length, against the garage and seal from there out to the entrance. Had the Celica pushed out of the garage so that I could get around her. Washed out the inside with fuel to get rid of the tar rich sound deadening. The floor seals leaked spilling fuel and tar onto the concrete. I noted this and washed it down, washing the fuel out of the fuel / tar mix and sealing the tar to the concrete. Switched off the water and began to attempt to scrub up the tar mess (to no avail) then noted that the fuel I had washed from the concrete had hit the seal and simply chewed through a 20cm section.
Chewed through $800 worth of CV cages by assembling them into the CV incorrectly.
Broken two Summers stub axles at $360 US each, by not torquing them correctly.
Done the bonnet pin thing on my AE86 rally car, thankfully only destroyed the bonnet didnt smash the windscreen.
Did the bonnet pin thing, without bonnet pins, (IE didnt latch the bonnet correctly) on my SW20 road car.... twice. Broke the windscreen both times, had a nice little score on the roof where the bonnet finished. On the same car I also spent 6 months climbing out the drivers window as I couldnt figure out how to get the doorcard off while the door was closed, in order to fix the door release. That car just plain hated me.
Mmm, Boost wrote:Kahlua wrote:Also been working under the bonnet and gone for a test drive, only to come back and find half the tools I was using still lieing around the engine bay. (x too many to remember)
Crap, I've done that too. Lost my 10mm spanner the other week
badidas wrote:i was about 18 on one of my ae82 fx's doing an oil change so cars nice and hot because id just driven to get the oil and filter jack it up, undo the sump plug hot oil burns me and i drop the plug into a bucket ... then there is more oil in the car than the bucket can hold it overflows all down my mums driveway meanwhile im sticking my arm in boiling hot oil tryna retrieve the sump plug in the end i got up and let it all piss down the drive while kicking things and swearing
oh and when i was 16 lend my mate my 323 to go to the shops throttle jams wide open so he drives it back like that shutting it off at lights ect, by the time he got home the clutch was fryed so badly it wouldnt move, we had seen an abandon 323 behind the shell gassy so off we go to get a clutch undo every bolt take to the starter motor with a hammer because the bolts were rounded off smash that off spend 4 hours wondering why the gearbox wont come off then realise theres a peice of starter left on and the bolts were holding the gearbox on this is in the middle of the night too
Infinite wrote:badidas wrote:i was about 18 on one of my ae82 fx's doing an oil change so cars nice and hot because id just driven to get the oil and filter jack it up, undo the sump plug hot oil burns me and i drop the plug into a bucket ... then there is more oil in the car than the bucket can hold it overflows all down my mums driveway meanwhile im sticking my arm in boiling hot oil tryna retrieve the sump plug in the end i got up and let it all piss down the drive while kicking things and swearing
so u smashed up some ones stolen 323 for its clutch?
