2jayzgte wrote:Another option is putting JZA 80 4-pots and big rotors up front that will definitely do the job.I no of a place Wgtn that is selling the rotors and callipers brand new out of Toyota for $750..
fivebob wrote: then you're in for an expensive and frustrating experience trying to get the brake balance correct
fivebob wrote:2jayzgte wrote:Another option is putting JZA 80 4-pots and big rotors up front that will definitely do the job.I no of a place Wgtn that is selling the rotors and callipers brand new out of Toyota for $750..fivebob wrote: then you're in for an expensive and frustrating experience trying to get the brake balance correct
Also they don't fit without a lot of modification
2jayzgte wrote:I've seen a few owners with MR-2s in Japan with this mod and they absolutely rave about it..
2jayzgte wrote:fivebob wrote:2jayzgte wrote:Another option is putting JZA 80 4-pots and big rotors up front that will definitely do the job.I no of a place Wgtn that is selling the rotors and callipers brand new out of Toyota for $750..fivebob wrote: then you're in for an expensive and frustrating experience trying to get the brake balance correct
Mmm, Boost wrote:My guess is Supras will have more front bias than an MR2....got pirouette?
sergei wrote:My theory (just speculation) is:
obviously supra callipers have much more volume of fluid than stock MR2 calipers, so to get same movement it will require more movement of the pedal -> which will result more force at the rear (which will result of rear lock up).
sergei wrote:Arent the front and rear almost separate system? I am thinking of that because there are 2 seals in master cylinder which feed 2 different tubes? And in fact there is a spring between rear and front shaft in the master cylinder so the rear would activate first then when the spring is compressed the rear shaft pushes front which applies pressure to front circuit?
Please correct me if I am wrong. I am drawing these conclusions from liteace van master cylinder which I dissasembled (and reasembled) a while ago...
