Gutless GT4 PLEASE HELP!
Postby Tania » Mon Feb 05, 2007 1:00 pm
Hi guys,
I have a 1990 GT4 and I'm having a little trouble with her. :x When she's cold she is completely gutless off turbo. :cry: Eg. in 1st, 2nd & 3rd gear I can put my foot to the floor and she may go about walking speed until she hits the turbo and launches. The problem seems to disappear when she warms up though. It's making it really difficult to pull out of intersections etc. I just had an exhaust manifold leak fixed and thought this would fix it but it hasnt. Anyone got any ideas what the problem is/what I should check? :?: Thanks!
I haven't failed.... I've just found ten thousand ways that don't work
Tania
Postby HELBND » Mon Feb 05, 2007 1:07 pm
dont put your foot down when its cold ;)
HELBND
Postby Boosted_162 » Mon Feb 05, 2007 1:08 pm
Checked the plugs? I got random misses and lost power from fouled plugs.
Postby flygt4 » Mon Feb 05, 2007 1:23 pm
all gt4's are pretty sluggish when cold, they limit the boost to like 5psi until its up to temp. are you sure its not that? from what you say it sounds a bit worse than that tho :lol:
flygt4
Postby Tania » Mon Feb 05, 2007 1:40 pm
Well even if I don't put my foot down it goes nowhere.... so i have to put it down to get the turbo to kick in, otherwise I would never be able to pull out at intersections.
Haven't checked the plugs yet but will try to... just got no time.... since all the intercooler has to come off it will take a while wont it? How long do you think it will take me? So if its better when its warm could it still be plugs? I'd have thought that it would have other problems too if the plugs were fouled.... I don't know though... I am just a girl :roll:
Yeah its mpore gutless than it should be, I've owned a non-turbo previously and it was nowhere near this gutless. Like I say, I can get my foot to the floor and it goes no faster than walking speed.
Thanks for the help guys... I appreciate it! :D
Tania
Postby Silent Knight » Mon Feb 05, 2007 1:43 pm
Where do you reside?
If you are in Auckland and can't manage to get the I/C off etc by yourself then I'm sure there would be someone willing to do the job for a couple of cold ones.
...me included. :wink:
Silent Knight
Postby Boosted_162 » Mon Feb 05, 2007 1:48 pm
If you havent done it before, leave yourself about an hour. Ive got it down to a skill, and can do it in about 15-20mins :P
Dont do it while the cars hot, the interwarmer will burn you!
Postby GTCRSHR » Mon Feb 05, 2007 2:04 pm
Silent Knight wrote:Where do you reside?
not if she wasnt a girl you wouldnt :P
Nothing to see here ...
GTCRSHR
Postby Tania » Mon Feb 05, 2007 2:06 pm
I live in West Auck... I'll give it a go one night this week... maybe my brother will give me a hand. Any tips for doing it? Should I just get some Denso plugs if I need new ones? or would you guys recommend something else? Cheers guys! :D
Tania
Postby Tania » Mon Feb 05, 2007 2:09 pm
Boosted_162 wrote:If you havent done it before, leave yourself about an hour. Ive got it down to a skill, and can do it in about 15-20mins :P
Hehe interwarmer... I love it! I know I'm just a girl :roll: but i'm still not silly enough to work on a hot engine!
Tania
Postby Boosted_162 » Mon Feb 05, 2007 2:12 pm
The problem is the interwarmer retains heat for ages!
Just get the plugs listed on the japanese sticker on the bottom side of the bonnet. If your running higher than stock boost, wouldnt hurt to go one plug colder. If you cant find the sticker, i can look on mine.
Postby Silent Knight » Mon Feb 05, 2007 2:13 pm
Course I would. I'm always here to lend a helping hand. :D
Be sure to drain the water/antifreeze before ripping everything off.
Remember to try and remember where everything goes once you take it off. :lol:
I'd normally go for NGK Iridiums but Platinum should be fine for a 3S... ?
Not sure what sort of gap they need, one of the 3S boys should be able to enlighten you...
Silent Knight
Postby Boosted_162 » Mon Feb 05, 2007 2:15 pm
Silent Knight wrote:Be sure to drain the water/antifreeze before ripping everything off.
Why would you do that? :lol:. Its only a air-to-air cooler, not a water-to-air :lol:
Postby Silent Knight » Mon Feb 05, 2007 2:17 pm
aaH my bad then. Thought all the 185s had WA. I'm guessing it's just the RC that had that then?
Silent Knight
Postby Tania » Mon Feb 05, 2007 2:19 pm
Yeah just standard interwarmer (sorry I'm stealing that!) Its a 3SGTE methinks! Just the ST185 GT4... :) Thanks again i do need as much help as I can get! Also anyone know where I can get the standard tweeter covers from? previous owner ripped them off (DUH!)
Tania
Postby fivebob » Mon Feb 05, 2007 3:26 pm
You're probably wasting your time replacing the plugs, as given your description of the problem (i.e. Gutless when it's cold, ok when it's warm), it's unlikely to be the plugs.
Gutless, as opposed to misfiring, is more likely to be a fuelling problem, so I would look at the temp sensor, or the cold start injector, either of which will require a bit more mechanical aptitude to diagnose than changing the plugs. The temp sensor can be checked with a multimeter, the cold start injector may require some special tools.
Another possibility is the perennial 3S-GTE problem with the rotor, cap and leads, which might need replacing, but again they’re more likely to cause a misfire, not just a lack of power, and again they wouldn’t cure themselves when the engine warms up.
Postby Loudtoy » Mon Feb 05, 2007 9:37 pm
Lots of black smoke when you put your foot down when it's cold. Any one here think it could be the oxy sensor or do they run closed loop when cold?? If you haven't done plugs while you've had it or suspect previous owner hasn't done anything to it then it would be worth pulling them out and changing them anyways. Plugs should be pre gapped if you use the right ones and if you don't you'l have more to worry bout than just the gap anyhow.
Some one other than me will be able to tell you if the 3s's in the 185's use a singe wire oxy sensor or not, might just not be gettin up to temp quick enough and if you say you just had exhaust manifold leak fixed it may be that they have damaged it whilst it was getting done. Either that or they've inadvertantly got two vacume lines crossed somewhere
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby Malcolm » Tue Feb 06, 2007 12:31 am
plugs are a very easy job, even with the RC w/a it only takes like 10 mins from when you start dismantling to having it running again. But as fivebob says, bad plugs wont cause your issue. Does it make any funny sounds when it's playing up? A misfire will cause popping and a certain amount of jerking. Have you run an ECU diagnosis? If not that would be the first thing to do, there should be something in the FAQ explaining how. I'll bet you have a dodgy connection on a sensor
Postby matt dunn » Tue Feb 06, 2007 1:18 am
What fuel do you run it on,
and
Has the ign timing been checked?
Postby larryex » Wed Feb 07, 2007 10:45 pm
All cars run in closed loop mode when they are warming up. In fact they are only in open loop at light throttle in cruise mode, that is the only time the ecu is actually responding to information from the oxy sensor.
When you use full throttle, or idling, or in warm up it runs on its preset closed loop programs. the oxy sensor is only really there to satisfy emission laws in japan etc which is why most NZ new vehicles are not fitted with them, other than Oz spec cars.
As for the young ladies problem yes the cold start injector is a good place to start or the CTS.
Chris
larryex
