Norty wrote:As i understand it (from looking around when i got my GTZ)
A BOV is simply a bypass valve that gets vented to the atmosphere. They do the same thing, only one vents to the atmosphere the other back to the intake tract. You can put a blowoff valve on a supercharged car so long as the mass air meter is setup for blow through, that way you don't vent off metered air.
is this correct guys?
I wouldn't waste my time if you want that wank factor then do what i did and get a turbo as well
Adamal wrote:As the S/C is run off the engine, its revs are directly proportional to the revs of the engine, unlike a turbo which will still try to create a positive pressure when the engine revs drop.
Result is compressor surge as the pressure keeps increasing as less of it is being consumed by the engine. That causes the turbo to suddenly halt and be forced to spin the other way (Which is compressor surge). That or its gonna put a huge hole in your intercooler![]()
My paragraph construction is pretty damn messy there, but I think you get the idea
m4vr1k wrote:Okay, on my system, unless i figure out a way to replicate the 4AGZE system, the supercharger will still be going when the throttle is closed, so it seems to me that i would in fact need a bov on my system, yes?
vvega wrote:ift the tbody is before the s/c its not nesacerry
if the tbody is after the s/c a bypass valve is required(read plumback bov)
