KE70 Brake Upgrade
KE70 Brake Upgrade
Postby Crucible » Wed Feb 14, 2007 5:47 pm
A workmate just fitted a holden v6 into his Ke70 wagon, and was wondering if there are any bigger calipers/rotors etc that will go in without too much hassle??
any ideas???
Crucible
Real Life Mechanic
Postby big_boy » Wed Feb 14, 2007 10:10 pm
if i rembour corectly with the correct spacers they fit MA61 breaks witch means with the correct spacers they will also fit skyline R32 if thats correct i will get the skyline part #`s for you
this is front only
for sale EE90
big_boy
Postby Crucible » Thu Feb 15, 2007 12:36 pm
big_boy wrote:if i rembour corectly with the correct spacers they fit MA61 breaks witch means with the correct spacers they will also fit skyline R32 if thats correct i will get the skyline part #`s for you
this is front only
Crucible
Real Life Mechanic
Postby big_boy » Thu Feb 15, 2007 8:36 pm
280x30mm Z32 300ZX rotors/calipers
Z32 Calipers - $240 posted, off EBay.
Z32 280x30mm slotted rotors, new - $100 each from RDA (http://www.rdabrakes.com.au)
Caliper rebuild kit - $30
EBC Greenstuff pads to suit above calipers - $175
New brake lines (2" longer) - $50
Machining hubs - $20
Rings and spacer cost - will be about $50
New hub seals - $8
New splitpins - $1
New 8mm longer studs - $30
Total cost ~ $800
Caliper rebuild kit
ATAP part, SJ6070 - ATAP PART NO LONGER EXISTS, new part number is
PROTEX - 210E-0011
Extra seals are from a Gemini front caliper, not sure what model though.
Rotors
280x30mm RDA909/DBA909
Pads - EBC Greenstuff
to suit 280mm DP21200
DP31200 RedStuff is also available
Seals
You can just get these off the shelf from anywhere.
Like all Toyota seals, they are factory NOK seals (or equiv), so any parts store can get replacements
Thats all the parts you need
if that helps that makes you 4 pot in the front
for sale EE90
big_boy
