sergei wrote:asweetdude wrote:Sounds very tempting, but still, dont know if the engine will handle the extra boost. what does a CT20B run anyway? Keeping in mind that my car has done 194000kms. Although it doesnt smoke or show any signs of having mechanical issues.
Hey I have ST165 with CT20b on it, the ST165 had done over 200000kms, and I tell you CT20b did get me from 15.0 to 13.5 quarter mile. With CT20b and 16.5psi I get ~180kw at the wheels. The only problem I have with CT20b is when I put 3" exhaust system it started overboost all the time.
So if you have stock exhaust system (or atleas 2.5" piping) you should be fine.
For me it did a big difference, no loss of power after 5500rpm for sure...
I think for 300Hp or near at the flywheel CT20b is the best turbo.
Generally 300Hp should be plenty for road car, while keeping it drivable, of course you could put all those fancy turbos (to get 400+Hp) but the problem with them that the power curve will be very peaky and car will be very sluggish to drive.
One would gather you never found a solution to the overboosting.
