Odd Engine Noise
Odd Engine Noise
Postby supraman_nz » Fri Feb 16, 2007 7:23 pm
Car is a 99 Carmy - 2.2L.
Been running great for years but its suddenly started making an odd noise at around 2300 RPM. It sounds like a tinny rattle in the engine that only comes on during 2300 RPM ish above and below it is normal.
Cars a manual if that makes any difference.
Any ideas what it could be? Is it worth getting checked out?
Thanks in advance guys
supraman_nz
Postby fangsport » Fri Feb 16, 2007 8:29 pm
blown fuse for the flux capacitor?
fangsport
Postby fangsport » Fri Feb 16, 2007 8:31 pm
likely to be a heat sheild or an exhaust bracket.
fangsport
Postby solitaire » Sat Feb 17, 2007 1:41 am
fangsport wrote:blown fuse for the flux capacitor?
Dude... Flux Capacitors dont have fuses :lol:
AE92, KZJ120, KDJ120
solitaire
Postby KinLoud » Sat Feb 17, 2007 7:47 am
We had a very similar thing - turned out it was the exhaust bracket under the sump was cracked.
I replaced the flux capacitor on our camry when we had an odd rattle... didn't fix the noise but I ended up in 1957 when I went over 139.68 kph! (88mph). I never even knew that the flux capacitor had failed!
Ken
Ham
021 408 863
Postby fangsport » Sat Feb 17, 2007 8:39 am
mate, if you have your one hard wired to the power supply, you're running the risk of either a major meltdown, or getting stuck somewhere in time if you get you're wires crossed :roll:
fangsport
Postby supraman_nz » Sat Feb 17, 2007 10:38 am
So either the
- heat sheild
- Exahust bracket
- flux capactor :lol:
supraman_nz
Postby Akane » Sat Feb 17, 2007 11:54 am
Make sure you have 1.21 Jiggawatts or else you won't be able to trigger the flux capacitor.
