what injectors to use??
Postby TOYROTA » Fri Feb 16, 2007 1:45 pm
im building a 7agte for my kp60 and im just curious as to what would be a good injector to use also what cc?
will go expensive aftermarket a bit later however would there be any other descent interchangable ones that i can get off other cars?
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Postby big_boy » Fri Feb 16, 2007 2:14 pm
i can sell you some 7M ones cheep 303cc
for sale EE90
big_boy
AYE
Postby TOYROTA » Fri Feb 16, 2007 2:57 pm
are they bigger than 4agze ones, also do you know what boost/hp can thay support up to?
Curre3nt rides-
TOYROTA
Re: AYE
Postby matt dunn » Fri Feb 16, 2007 7:16 pm
TOYROTA wrote:are they bigger than 4agze ones,
no GZE's are 365
TOYROTA wrote:also do you know what boost/hp can thay support up to?
Not enough.
Postby atmosports » Fri Feb 16, 2007 9:41 pm
It's kinda hard to suggest an injector without knowing what sort of power you are expecting etc. I'd say if you are going with a 7AGTE being turbo'd etc you'd want a minimum of a 400cc/min injector in which case a 440cc/min out of a 7MGTE would suit just fine. In saying that I'd say anything up to a 650cc/min injector would be ok unless you either chasing heaps of power in which case you may need larger or else if you aiming for bugger all power you may need to go smaller. Whichever way you go obviusly make sure the rest of the fuel system is up to spec.
atmosports
Postby Caveman » Fri Feb 16, 2007 10:06 pm
IIRC 500cc/min will supply 100HP
Good ones ive seen working on 4ages are 4agze, sr20det and rx7 turbo injectors.
My 4agze injectors were flowed at 430cc across all four. The guy that did the work (petroject in albany) said he got a similar result from the last 4agze ones he did,
AW11 Track Toy
Formerly known as 1998
Caveman
Postby matt dunn » Fri Feb 16, 2007 10:42 pm
Caveman wrote:IIRC 500cc/min will supply 100HP
That's not a typical result then as I have done at least 3 sets of 4AGZE ones at work and they were all 365 +/- 10.
Postby Caveman » Fri Feb 16, 2007 11:26 pm
I will look for the results sheet but I was suprised at the ratings. This is at full duty cycle at 3bar, not at 80% cycle as typically quoted.
AW11 Track Toy
Caveman
Postby matt dunn » Sat Feb 17, 2007 12:38 am
Yeah thats what we test at too. Wide open and 3 bar ( about 45psi ).
Caveman wrote:not at 80% cycle as typically quoted.
That will be why my 440 side feeds flow 500 and my 550's flowed 600.
matt
Postby Lloyd » Sat Feb 17, 2007 8:49 am
I flowed my 365s and worked them out to be getting pretty close to 440. I could have been working it out wrong from the ms and rpm setting on the machine though. All were exactly the same
Postby Caveman » Sat Feb 17, 2007 11:52 am
Well I had a look for the flow sheet but ive lost it :x You'll just have to take my word it was 430cc with all four within 99% of that.
AW11 Track Toy
Caveman
