fuse keeps blowing - corolla tail lights
Postby sigma » Mon Feb 19, 2007 1:51 pm
When i bought my 93 Corolla, the tail lights didn't work. Just a fuse I thought, and i was right, found the offending fuse and replaced it. A week ago, I was informed my tail lights were out again. The replacement fuse had gone. Had a pack of 5 in the glove box so I just put another in 5 minutes ago, turned the lights on and bang, blew straight away. Its a 15A fuse.
So im guessing my car has some sort of electrical problem? Can anyone suggest what could be causing this?
1985 MR2 AW11 20v
sigma
Postby Alex B » Mon Feb 19, 2007 1:57 pm
See if it happens with the stereo turned off, im guessing the dash lights don't work either? Basically if its what im thinking, some monkey has used the green illumination wire an an earth for the head unit.
Postby sigma » Mon Feb 19, 2007 5:22 pm
You are right the dash lights are gone too. Just tried it again with the stereo off but it still blew the fuse. So what is this illumination wire you speak of?
1985 MR2 AW11 20v
sigma
Postby TRD_ZERO » Mon Feb 19, 2007 5:43 pm
Well i had a similar problem with my ep71 turbo. It happend after i removed the rear spoiler then put it back on. I ended up pinching the rear spoiler spotlight wires which cause the rear light to fuse all the time. Although i think my dash lights did work, i dnt really remember. All we did was isolate the problem working back to front.
TRD_ZERO
Postby Mr.Phreak » Mon Feb 19, 2007 6:16 pm
pyro_sniper2002 wrote:See if it happens with the stereo turned off, im guessing the dash lights don't work either? Basically if its what im thinking, some monkey has used the green illumination wire an an earth for the head unit.
Having the Stereo on or off won't matter, as the unit is generally still grounded, and as soon as 12v ramps up that wire the fuse will blow, you actually have to disconnect the wiring to test if that's the fault.
Mr.Phreak
Postby matt dunn » Mon Feb 19, 2007 10:58 pm
Mr.Phreak wrote:Having the Stereo on or off won't matter, as the unit is generally still grounded, and as soon as 12v ramps up that wire the fuse will blow, you actually have to disconnect the wiring to test if that's the fault.
Correct,
you need to remove the stereo and then put in a new fuse and if the problem is gone get your stereo wired up correctly.
Postby sigma » Mon Feb 19, 2007 11:52 pm
Gotcha, will pull the stereo in the next few days to check. So what is this 'illumination wire' and where does it usually connect to? I was there when we put the stereo in. My mate did it who's done many before, checking the wires with a multimeter. There was no stereo in the car when i got it, just the factory loom that had been cut behind the plug.
1985 MR2 AW11 20v
sigma
Postby Mr.Phreak » Mon Feb 19, 2007 11:59 pm
The Illumination wire is a switched 12v line that dims the headunit display so it's not distracting at night. It's to be connected to the unit's Illumination wire if it has one, if it doesn't just insulate it.
It will measure as a ground normally, but will measure +12v when you turn your lights on.
Mr.Phreak
Postby solidog » Tue Feb 20, 2007 1:11 am
Is your park light circuit, so u wont have any on the car when the fuse goes, its such a common problem where amateurs have wired the stereos earth to what appears to be a good earth, except when the lights are turned on it feeds that wire and pop goes the fuse.
-=4age inside ~ Allmotor Toyota=-
I know stuff, im modest, I get involved
Yeah newtown ae that me! Did you know "Newtown : Its a bit shit!" but not me!
solidog
Postby Mr.Phreak » Tue Feb 20, 2007 8:58 am
It's not just amateurs who have been caught out by it.
Mr.Phreak
welll
Postby solidog » Tue Feb 20, 2007 11:17 pm
im not amateur anymore! yeah people who don't know! like my old school boss who wired an amp to the aerial switch, no doof doof with cds! i laughed!
solidog
Postby blackmk3 » Wed Feb 21, 2007 12:31 pm
I did this exact same thing installing a stereo into my mates MR2, found a earth sweet and couldnt understand what the fuse popped when the lights went on, figured out it was the innumiation wire, DOH! lesson learned 8)
If failing that i had a problem with a dodgy brakelight bulb on my wagon, occasionally it would work and other times it would short straight to earth and blow the fuse, new bulb and a clean up of the terminals and she was good as gold again
Mk3 MA70 Supra
blackmk3
