How do i mod a diesel engine????
Postby stalker » Thu Feb 22, 2007 10:58 pm
AHAHAHHAHAHAHAH...i actually want to mod my 2.4 diesel engine!!!
Yes i know...im mad, but hey, its something different :twisted:
Now i must admit, i know i wont be doing 10sec 1/4's or anything, but i wouldnt mind wiping the smiles off some of the honda owners out there!
I havent quite decided yet as to sticking with my current 2.4, or upgrading to the 3ltr turbo diesel engine, but any mod tips i can get will help no matter which way i go.
does anyone have ANY ideas on how to mod a diesel and where to start etc??????????
:lol:
p.s. oh yea, i want to keep the diesel engine as i drive at least 100kms each day!
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
Postby Phothog » Thu Feb 22, 2007 11:04 pm
like any vehicle...
start with an exhaust & filter.
if its turbo go for a 3" exhaust...
Phothog
Postby strap-on » Thu Feb 22, 2007 11:06 pm
funnily enough the work van from my old work had the 3 litre turbo diesel slightly modified.
just a good exhaust a good air filter and it felt heaps better, the shop did something else to it which i dont think the boss understood so could never fully explain but i get the feeling they either mucked with the afm to trick the computer, or just simply upped the boost somehow im not quite sure, i reckon go for the 3 litre turbo if you know what your doing and can do it relativily straight fowards
strap-on
Postby stalker » Thu Feb 22, 2007 11:07 pm
Thanx heaps....yea i have those in the works to get done.
and sadly no its a non-turbo, so i was wondering what else i could do without going to the expense and hassle of doing an engine swap???
stalker
Postby strx7 » Thu Feb 22, 2007 11:15 pm
its all in the injector pump timing, if you haven't got a puffer on the side you're bag of tricks is pretty empty before you've even started unfortuneitly
However I can hook you up with a set of new headers with the gasket supplied for $230 + freight + gst
Shane
Postby matt dunn » Thu Feb 22, 2007 11:23 pm
you can if you know what you are doing adjust the fuel quantity mixture in the pump.
Dad did it to our 2.4 non turbo.
You need to be careful though as a little bit of movement is a big lot of adjustment.
Postby evil_si » Thu Feb 22, 2007 11:46 pm
can tweak the fuel screw on back of the pump,
if you go to far it will lose power and black smoke like a bitch,
1/4- 1/2 a turn is the most youd want to try.
it is the screw that is lock wired, has a lock nut and an adjuster screw in the center.
only thing id ever bother to do to one is turbo it,
a lot easier to turbo a diesel than a petrol
evil_si
Postby mr pad » Fri Feb 23, 2007 9:44 am
2.4 non turbs... you will never get that scaring anything at the lights.
Solid as motors, but I would be suprised if you could do over 120kmph...
mr pad
Postby Dell'Orto » Fri Feb 23, 2007 10:16 am
Swap it for a 1KZTE, and up the boost a tad ;)
Postby stalker » Fri Feb 23, 2007 10:38 am
lol...surprisingly i have had that up to 128kms (at 4500RPM) so i didnt have much left to go...R-lines at 5000
:lol:
stalker
Postby matt dunn » Fri Feb 23, 2007 1:00 pm
mr pad wrote:2.4 non turbs... you will never get that scaring anything at the lights.
Our 2.4 2wd Hilux can do 120 towing my race car.
Unhook the race car and it may get to 121.
Postby mycoolcar » Fri Feb 23, 2007 8:19 pm
Had a 3L auto toyota diesel up to 130k on the motorway, it didn't want to go any faster and neither did I.
mycoolcar
Postby fangsport » Fri Feb 23, 2007 8:53 pm
you sure the absolute top speed goes up when empty??
we had an old 2.4l Hiace when i was carting furniture that topped at 110km/h empty, but would sit on 130 loaded to the gunwhales and trailer in tow.
to make it go better, open exhaust, let it breathe, and micro time the injector pump. i suppose a reprofiled cam may create a gain as well.
fangsport
Postby TrouserFxGt » Fri Feb 23, 2007 8:55 pm
With an opened up inlet and exhaust my 1.5 starlet can do 155. On that car getting rid of the factory inlet hose made the biggest gain.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby loudsir » Fri Feb 23, 2007 10:13 pm
I used to drive a Nissan Vanette 2.0 non-turbo diesel (late 80's one I think) the speedo only went to 140km but I had it off the clock on the motorway numerous times. Took its time to get there but didn't seem to mind doing it, never overheated or anything. Going around corners was a different story though!
loudsir
Postby mr pad » Sat Feb 24, 2007 12:48 am
[quote="TrouserFxGt"]With an opened up inlet and exhaust my 1.5 starlet can do 155.quote]
:lol: :lol: :lol: :lol: $&#$% awesome.
mr pad
Postby matt4u » Sat Feb 24, 2007 1:05 am
The 2.4's are known for S#$tting the self with getting more power out of them, to be honest most hi power diesel motors dont like heads. The 1KZ's dont like heard either.
Bite the bullet and sell the diesel engine and throw a supra engine in it. From my 2.4 turbo D to the 2.8 5mgeu cost about the same to run once you account for road tax. You wont regeret the swap, it makes them such an easy nice truck to drive.
SupraCelicaLuxSurf
http://www.offroadexpress.co.nz/images/ ... ui_001.jpg
ADMIN EDIT: oversized image removed
matt4u
Postby Elmo » Sat Feb 24, 2007 8:41 am
Lucky to get 120? Man, that sucks, Ive had my 2.8t to over 150 does it quite easily :-D
Elmo
Postby Bling » Sat Feb 24, 2007 10:58 am
that was crossing the Waimak river too wasn't it Elmo? :lol:
Postby Mr Revhead » Sat Feb 24, 2007 12:43 pm
bolt an sc14 running 6-8 psi!
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
