Matt Dunn supplied me a 20v one to change over the end to suit the smallport redtop with reduction .ChaosAD wrote:So you mean I can replace the end of a silvertop starter with one off a bluetop starter to make it into a redtop starter?
will have to be redtop, unless the blue top is a reduction gear starter. the reduction type are completely different to the direct drive ones.ChaosAD wrote:kewl,but can i use a bluetop end? or does it have to be a redtop one?[/i]
gepsk8 wrote:sounds like brushs to me
