do KE70 discs fit AE85 struts?
Postby ke25sr » Mon Feb 26, 2007 7:02 pm
Do they swap straight over do they have the same bearings?
Has any 1 bought the bush's/sleeve off trademe to change the ball joint size. So you can fit the different steering arms in starlet or KP's
ke25sr
Postby crispy'86 » Tue Feb 27, 2007 7:00 am
ke70/ae70/85/6 should have same bearing sizes,
as for the spacers couldn't tell you
crispy'86
