20V AE101 running rich - how to fix?
Postby fuel » Tue Feb 27, 2007 11:55 pm
Hey guys, my flatmate has a '92 AE101 20V Levin which is running hella rich - it is white and the rear bumper and boot gets absolutely covered in soot soon after being washed.
It has done about 180,000kms but being a Toyota it should be sweet - right?! I've been driving it a bit these last few weeks and it doesn't seem all that quick eh, and just doesn't seem to have any balls at all in the high rpm range. It's not running rough at all and seems to be accelerating smoothly, and it idles sweet as too so I figured the spark plugs are all good. Oil and filter have been recently changed too. The only mods are a pod filter (which seems pretty clean) and a big f**k off noisey muffler at the rear.
Any ideas? cheers
LOUD NOISES!!!
fuel
Postby aesc » Wed Feb 28, 2007 8:56 am
ECU water temp sensor?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby cogent » Wed Feb 28, 2007 9:51 am
I have similar problems with mine, ive just checked my VVT last night and its dead/not working :(
cogent
Postby fuel » Wed Feb 28, 2007 11:57 am
How would I check if the VVT is working or not? I notice it takes like 10 minutes for the thing to be fully up to normal temperature and until then it idles at like 1400rpm.
Even when it fully warms up it still doesn't run any better and blows lots of black smoke.
LOUD NOISES!!!
fuel
Postby slighty_sykotic » Wed Feb 28, 2007 12:19 pm
slighty_sykotic
Postby big_boy » Wed Feb 28, 2007 2:48 pm
im going to say by your last comment it sounds like thermastat & posabaly WTS
for sale EE90
big_boy
Postby AceSniper » Wed Feb 28, 2007 3:16 pm
VVT, Thermo
dirty throttle bodys(pcv oil), possably injectors
soot has prolly cloged/killed o2 aswell
Trigger the vvt when its idling it should run rough
AceSniper
Oxygen sensor
Postby andyztouring » Wed Feb 28, 2007 6:41 pm
Faulty oxygen sensor will make them run very rich.
andyztouring
Postby Lloyd » Wed Feb 28, 2007 7:08 pm
I'd be starting with the thermostat and going from there
Postby AE82 FXGT » Wed Feb 28, 2007 7:14 pm
Not sure if it would fix your prob as it seems to be related to something else, but you air/fuel can be tweaked slightly by the little bypass bit on the AFM. You'll need an exhaust analyser to do it right though.
AE82 FXGT
Users browsing this forum: Bing [Bot] and 13 guests
