tumble weed... and runx doing odd things
Postby barryogen » Wed Feb 28, 2007 12:27 pm
so... nothing interesting happening with Toyspeed in Dunners at the moment huh?
The Runx is doing some odd things again. A few weeks back it started randomly pulling either left or right while driving, not hard left or right, just enough to let me know.
http://forums.toyspeed.org.nz/viewtopic.php?t=54203&highlight=
It ended up being diagnosed as a bent suspension arm that looked like it had been belted with something, so it was replaced.
Now it has started doing it again, only a lot more noticeably, and there is nothing visible at all on the suspension arms.
The other odd thing it has done in the last week or so is full throttle for no reason at all, right foot wasn't burried, it just randomly did it, cruizing down the motorway, and it started accelerating, I hit the clutch, and it hit redline pretty much instantly.
I hit the pedal with my foot hard, and it didn't make a difference(fixed it in my old car when it did it), so I turned the car off, and back on, still stuck, left it a few mins, turned it back on and it was fine.
Your thoughts?
barryogen
2ZZ Guru in training
Postby Mr Revhead » Wed Feb 28, 2007 5:19 pm
fraying cable jamming?
stiff pivot?
your on drugs?
Postby john_l » Wed Feb 28, 2007 8:15 pm
the pedal thing happend to me before.. but totally my fault as i didnt have my pod filter screwed on fully nd it came off (cornering way 2 fast lol) nd got stuck pullin the gas cable down! got the biggest fright ay.. dunno bout the other thing sorry!
john_l
Postby barryogen » Thu Mar 01, 2007 8:51 am
followed the cable last night, all looks fine on the outside, and it moves freely so I would assume fine inside too, is there anything else that controls the throttle other than the pedal and cable? The car doesnt have drive by wire, they didn't use that until a few models later, but the pedal still had the same feel when it was accelerating as it does normally.
stiff pivot? huh?
not on drugs... havent done any of that in months.
And everything looks as it should in the engine bay.
barryogen
Postby Mr Revhead » Thu Mar 01, 2007 9:40 am
floor matts?
pull the intake pipe off and see what the buttefly looks like
Postby barryogen » Thu Mar 01, 2007 12:50 pm
Mr Revhead wrote:floor matts?
already pulled the mats out just incase, will check the butterfly when I get home... I'm not driving it much at the moment because of this you see.
barryogen
Postby barryogen » Fri Mar 02, 2007 8:37 am
butterfly thing looked fine, nothing sitting in there that would catch on anything, pulling to the right appears to have stopped for the moment too.
barryogen
Postby Mr Revhead » Fri Mar 02, 2007 8:47 am
not full of greasy crap or anything?
when it happened was the pedal stuck down? or was its movement/feel normal?
Postby barryogen » Fri Mar 02, 2007 8:50 am
there didn't appear to be any greasy crap in there, mild oil smell, but no more than a usual new ish engine bay.
Pedal feel was normal, which is why I don't think it is cable, but I'm not a mechanic at all, but I can follow logic puzzles, and this is just one big f*ck off logic puzzle.
barryogen
Postby Mr Revhead » Fri Mar 02, 2007 9:01 am
possibly an airleak after the throttle body then.
ring HRT and offer beer :D
Postby Alex B » Fri Mar 02, 2007 8:32 pm
Mr Revhead wrote:possibly an airleak after the throttle body then.
ring HRT and offer opel nura :D
Postby cozmoid » Tue Mar 06, 2007 11:30 pm
barryogen wrote: is there anything else that controls the throttle other than the pedal and cable?
This is caused by the TPS (throttle position sensor)
I have had this happen to me in my Rx7 and it didn't go away till I unplugged the sensor and turned over the engine(this reset the ECU's sensor values). Then plugged it back in and it never happenned again.
But if it's tricky and only sometimes I recommend getting your vehicle scanned for error codes. Then u will get the full jist of whats really going on. I u wanna call me at work I can set u up a time to come in and we can scan it and find the faults. I will try and get ya a good deal too
Shawn from Total Automotive 4773593
Ae70/Te71 Hybrid
viewtopic.php?t=54364
cozmoid
Postby barryogen » Mon Mar 19, 2007 11:14 am
All sorted.
There was a split tube after the butterfly, mechanic pulled it off, shortened it buy about 2cm(the split bit), and slotted it back on, tightened clamp, and it hasn't done it since.
Pulling was a loose bolt that had elongated where it was meant to be holding, hard braking/acceleration moved the suspension arm enough to bend it. replace arm again(ouch), and got the elongated bit done too.
Happy happy (but broke) Dave.
barryogen
Postby Mr Revhead » Mon Mar 19, 2007 11:22 am
do i get a prize? :twisted:
and u shoulda called me on the arm!
Postby barryogen » Mon Mar 19, 2007 11:23 am
Mr Revhead wrote:do i get a prize? :twisted:
sure... next time I buy something off you, chuck some margin for yourself on... Arm wasn't dear, plenty of wrecked corollas around.
barryogen
Postby cozmoid » Tue Mar 20, 2007 8:50 pm
Wasn't there a recall on some late model toyota's because of faulty steering/suspension arms lately
Ae70/Te71 Hybrid
cozmoid
Postby Mr Revhead » Wed Mar 21, 2007 10:09 am
hilux/surf.
nothing to do with the corolla
Postby barryogen » Thu Apr 26, 2007 2:33 pm
barryogen wrote:There was a split tube after the butterfly, mechanic pulled it off, shortened it buy about 2cm(the split bit), and slotted it back on, tightened clamp, and it hasn't done it since.
well, it did the full throttle thing again, hit ~140 heading up from GI to Lookout Point before I was braking, to pull round the corner(to stop), but it came right as I was just about to flick on the indicator.
Any ideas?
barryogen
