Ae92typeX wrote:Perhaps find out if runing a nz new or import loom/ecu?
l1ttle_d3vil wrote:if you do need one, your car will most likely just run richer than it should. do you have a small yellow round 1 pin plug on your loom? should be by the distributor, if you do thats for your 02 sensor.
Stealer Of Souls wrote:According to my toyota ae86 workshop manual..
Bluetops don't actually use the O2 sensor for anything.
2LTR Rona wrote:Hmmm that probably explains the richness of mine (someone else did conversion)
You are in fact speaking of this little yellow plug in question arent you ? (see pic)
