wheel off sets ??
wheel off sets ??
Postby big_boy » Fri Mar 02, 2007 9:53 am
im getting some nwe wheels for my car but i dont quite under the off set i need i want 16*8 on the back & 16*6.5 on the front & will be running 245/45-R16 on the back & 205/50-R50 on the front
first question is will these fit on these rim sizes so a 205 on a 6-1/2" rim & a 245 on a 8" rim
next question is off set
on the back from the mounting face 46mm to the gaurd lip & i have 165mm to go back & my break callper over hangs the mounting face by 6mm
on the front i have 60mm from the mounting face to the gaurd lip & 108mm behind the wheel at full lock ither way & my callper over hangs by 30mm
the wheels i want to get are simmons OM
also the wheels i have at the moment have 6J*14-4*114.3 on them what douse this mean ?? the 6J bit
for sale EE90
big_boy
Re: wheel off sets ??
Postby postfach » Fri Mar 02, 2007 10:18 am
big_boy wrote:first question is will these fit on these rim sizes so a 205 on a 6-1/2" rim & a 245 on a 8" rim
yes they will fit
big_boy wrote:also the wheels i have at the moment have 6J*14-4*114.3 on them what douse this mean ?? the 6J bit
6 is the width of the rim, J i think has something to do with the strength or the lip? not 100% sure on that bit
postfach
Postby postfach » Fri Mar 02, 2007 10:33 am
i knew there was a post somewhere about this, have a look at this thread, plenty of useful info for you:
viewtopic.php?t=53590
postfach
Postby big_boy » Fri Mar 02, 2007 10:35 am
ok i was hopeing J was an off set i could copy
for sale EE90
big_boy
Postby postfach » Fri Mar 02, 2007 10:37 am
the offset is usually stamped onto the wheel somewhere, will be a number like ET35, more than likely on the back surface of the rims somewhere, possibly on a sticker
postfach
Postby big_boy » Fri Mar 02, 2007 10:39 am
all i found was 1 sticker & that just has what i posted above
for sale EE90
big_boy
Postby Ae92typeX » Fri Mar 02, 2007 11:05 am
Aside from above confirming fit, the calculators on the linked post should be enough for you to confirm things.
Although the many of mags I see have a stamp identifying somewhere, Ive owned a few sets which have nothing at all.
Ae92typeX
Postby diss7 » Fri Mar 02, 2007 11:34 am
What is the wheel you have on it?
Most wheels only come out in one or two offsets per size, which will be on the net somewhere.
diss7
Postby diss7 » Fri Mar 02, 2007 11:55 am
After reading this thread - http://forums.celicasupra.com/showthread.php?p=128156
I would recommend these offsets in the widths you want
Front 6.5" rim -10 offset
Rear 8" rim 0 offset
I'd suggest going to a 7 inch rim at the front and 0 offset.
Makes it less of a random set, as far as resale goes. :)
diss7
Postby johntramp » Fri Mar 02, 2007 12:25 pm
johntramp
Postby AE85coupe » Sun Mar 04, 2007 10:12 am
6j = small, 205 tires will look silly as they will overhang the rim, even 195's on a 6j rim hang over a bit, get 7inch.. don't muck around
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby big_boy » Mon Mar 05, 2007 8:54 am
6J is whats on it at the moment with 185`s not what im putting on it
the wheel at the moment is a rays something
for sale EE90
big_boy
