4agze TRD spark plug leads
Postby Norty » Mon Mar 05, 2007 12:11 pm
Hey quick question
for the 4agze engine is the TRD part number for the spark plug leads
19051-AE011
OR
19051-AE001
or will either fit a 4agze or is it totally something different
What the Price for something like this to pay also
Norty
Postby aesc » Mon Mar 05, 2007 1:02 pm
I dont think TRD make leads for 4agze anymore, and 4age ones dont fit
http://trdparts.jp/english/parts_plug-cord.html
EX AE101 owner
2013 Ford Focus ST
aesc
Postby solitaire » Mon Mar 05, 2007 1:43 pm
If its an ae101 agze im 99% sure they dont make them...
Correct me if im wrong but i believe a ae101 gze is a smallport 4age engine... if so trd dont make them...
If its an ae92 gze (which i thought was a big port) the big port 4age leads should fit shouldnt they?
AE92, KZJ120, KDJ120
solitaire
Postby sergei » Mon Mar 05, 2007 1:54 pm
16v 4AGE have distributor in different location to 4AGZE coils so no 4AGE lead will fit (properly) to 4AGZE unless GZE has got distributor setup.
Postby Norty » Mon Mar 05, 2007 1:55 pm
Bugger
Ok so who does make leads for the 4agze ae101?
Norty
Postby big_boy » Mon Mar 05, 2007 2:03 pm
BNT have good thick reasnably priced ones witch my MR2 is running with good results over stock
for sale EE90
big_boy
Postby sergei » Mon Mar 05, 2007 2:04 pm
Stock leads are good enough BTW.
Postby sergei » Mon Mar 05, 2007 2:08 pm
Also if leads are not arcing through inulation or broken inside, there would not be any difference at all between brands (as long as they are high impeadance leads) in performance what so ever.
Postby big_boy » Mon Mar 05, 2007 2:09 pm
just for a note i dont really feal the power gain so much as see it on the scope im getting between 4,500-6,500 volt increase at the plug
for sale EE90
big_boy
Postby aesc » Mon Mar 05, 2007 4:06 pm
Norty wrote:Bugger
Funnily enough I think genuine Toyota leads thru Revhead were the cheapest option back when I had my ae101. NGK make them but I got quoted $170ish thru Repco.
BNT could probably order you some custom made Top Gun leads if you wanted the 8mm or 10mm type, you just need to give them the lengths of each and the type of connectors
EX AE101 owner
2013 Ford Focus ST
aesc
Postby TRD Man » Tue Mar 06, 2007 8:30 am
TRD never made leads for the ZE engine.
I agree with the suggestion - ring Warwick for some TGP items.
TRD Man
