Crampy wrote:The Silvertops are 43mm and the Blacktops are 45mm. The measurements are the butterfly size. They both have a bit of taper in them.
You can bore the Blacktop quads out to a 50mm butterfly, but I would imagine it wouldn't have any taper after that.
As for bolting the Blacktop throttles to a Silvertop manifold, yes you can. BUT. The ports are way different, so you'd need to get it matched. The throttle linkages are set up differently on each of them too.
The Blacktops have a vacuum accumulator, as they are MAP sensored from factory, this gives it a smoother vacuum reading at idle and high vacuum driving.
You can use Silvertop quads with MAP sensor, but it's best to make up a vacuum accumulator for them as well. Don't take the MAP sensor vacuum from a single runner, that is bad!!! OK....
RomanV wrote:What about TPS signal? as you've effectively increased your throttle body area massively... 5% open throttle is a lot different between the two, in terms of cross sectional area.
soopachargen wrote:i thought (read thought) that with ITBs that its different as you only have one throttle being sucked through at a time???
Users browsing this forum: Bing [Bot] and 23 guests
