2jzge, someone on these forums had an engine and auto box for sale i think.
torquey and pretty smooth, and not getting too silly on the gas.
Emperor wrote:yeah put a rota in it..
(Is it just turbo rotors that eat apex seals, or ported ones? Mine and dads have had the sh*t kicked out of them for years, and missed a beat, 10,000rpm+ launches, etc)
DVSMOTORSPORT wrote:I'm the guy KINLOUD talked about with the 5m-ge conversion, the hardest part of the conversion is finding the bell housing! once this is sorted it runs a standard 5m-ge clutch, straight onto the factory Hilux gearbox, the engine mounts need to cusomised, I cut the old ones off the chassis and moved them forward then welded them back on strengthing plates, but I mounted it slightly too high and had to cut the braces out of the bonnet, the sump needs customising to clear the steering rod but I just panelbeated it to save any welding.
Easiest conversion I've done so far, heaps easier than a lexus v8 in a Hilux!
And with a full twin exhaust it sounds horny! In the words of KINLOUD "It sounds like a v8 should at idle and then as it revs like a really hot skyline!"
matt4u wrote:
What about a 3.8 V6 holden??
