rollaholic wrote:im an apprentice mechanic and i've been doing all the work myself - im pretty keen to pull the inlet manifold off this weekend and have a good look for myself... it doesnt look too complicated from some of the pictures i've seen.
when rick mentioned the TVIS i smacked myself in the head and did some searches.
two heads better than one etc
pc wrote:few things off the top of my head
- 10degrees and the engine should run fine. Make sure you connect the diagnostic connector before setting timing though.
- TVIS may not be working
- ECU maybe incorrect for engine. There are different ECUs for the 16 valve, they all seem to work, but with varying results.
pc wrote:definitly sounds like something is wrong with the cam timing, a couple of teeth out or something like that. You will probably need to check the sprockets on another bluetop to be sure you have the right ones. The timing marks are really obvious, so you probably haven't got that wrong.
The indentation on the sprocket is on the tooth part, and is used to set the timing.
I can't remember if it's possible to get exhaust and inlet round the wrong way, IIRC there is only one way to put the sprockets on...
rollaholic wrote:for those interested, the problem was indeed cam timing - the crank sprocket had flogged out around the keyway, allowing the sprocket to slide back and forth on the crank shaft by 1/3 - 1/2 of a tooth or so. obviously this was translating into a much bigger problem by the time it had transferred to the cam timing.
additionally, one of the vaccum lines from the TVIS vaccum reservoir was not connected, i believe this one was self inflicted while i was taking out the heater pipes just below it to have them repaired. the cam timing was the main problem, but no doubt this was contributing to general lack of low rev torque.
at the risk of sounding like backyard bob i tidied up the damaged keyway and crankshaft end with some sellys knead it, and replaced the crank sprocket with another one i had handy. reset timing at 10 degrees and car is now driving like a dream... it begs to go sideways and i cant stop grinning.
thanks for all the advice folks.
RedMist wrote:Seems to be reasonably common on the 4age.
