1jz/2jz cam covers swappable?
Postby gmacrae » Wed Mar 14, 2007 11:15 pm
Howdy. Just wondering if anyone can tell me if its an easy job putting a stock 1jz-gte cam cover on a 2jz-gte (or vice versa)? Are the bolt holes in the same place? do the cams clear ok etc? Im not worried about the crankcase vents being different
Anyone got a pair of stock 1j cam covers they wanna flick cheap?
I know its not likely anyone has done this but just thought i'd ask.
Cheers - Gene
gmacrae
Postby Silent Knight » Thu Mar 15, 2007 7:14 am
Gene, I have rather large doubts about them being swappable.
Once the rain actually clears and I can get to my car I'll double check for you as I've got both 1 and 2J covers at home.
Silent Knight
Postby edwagon » Thu Mar 15, 2007 8:45 am
I actually think that they are swappable - the gaskets are certainly the same and Im fairly sure the boltholes etc all fit too
Just have to be careful swapping between gte and ge as the ge manifold runs across the rockercovers and the ge covers are the right shape to give clearance.
I did have a set iof 1jz-gte covers but im pretty sure they went to Oizo....
edwagon
Postby strx7 » Thu Mar 15, 2007 8:48 am
yeah i'm pretty sure they are swappable, 1JZ n/a and 2JZ n/a are swappable
Postby Silent Knight » Thu Mar 15, 2007 8:56 am
Hrmmm alright thanks Thads I'll get in contact with Adrian and see if his are still lying around so I can put them next to each other and find out for sure.
Adrian... you have 5mins sometime tonight or tomorrow night so we can have a quick mix/match or you still down south?
Silent Knight
Postby gmacrae » Fri Mar 16, 2007 12:53 pm
Thanks for the input lads - i want to put some 1jz-gte ones on my 2jz-gte, with a custom alum coilpack cover plate.
If you get the chance to look into it hanre, i'd really appreciate it :)
Or if someone wants to make their 1j look like a 2j i could do a swapsies i guess ;)
gmacrae
Postby Silent Knight » Fri Mar 16, 2007 2:56 pm
If I can get in touch with Adrian so I can borrow his I'll check.
Otherwise like I said we'll have to wait for a day when it's actually not pissing down outside for me to be able to take the covers off of the car to have a look for you.
Either way, I'll let you know if I find a resolution... :wink:
Silent Knight
