wtd wiring diagram
wtd wiring diagram
Postby IH8TEC » Thu Mar 22, 2007 12:00 am
hello
i'm in need of a wiring diagram for my car. before you say search, or go to club4ag etc, they dont have it and can't find one.
the car is a 1988 AE92 toyota trueno gtz with a AFM 4agze motor
not the only wiring diagrams i've found are for either a map sensored ae92 and ae101 gtz's or a 4agze mr2 whereas my car is the piggy in the middle.
anyone that has one, or knows where to get one, your help would be greatly appreciated.
thankyou
brendon
Postby matt dunn » Thu Mar 22, 2007 1:06 am
I did a conversion ages ago with an AFM AE92 loom,
The ECU pins are not labelled, and there appears to be no wiring diagram in existance as I have been looking for the last two years and never found one.
In the end I changed it and used a Map ECU and loom as there is info available on them.
IF you find one let me know.
Postby IH8TEC » Thu Mar 22, 2007 10:37 am
i need it to aid in wiring up the link. i guess it might be worth making a full new engine loom then?
Postby Caveman » Thu Mar 22, 2007 1:12 pm
I dont think you'll find one, but keep looking
I found that the afm wiring was similar to the n/a model (are you running map with the link?)
Have you considered tracing back from the sensors to the ecu pin? Then just remove the all the diagnositc wires (wont be able to use with the link)
Then its just the g1 g2 ne e dizzy pickup
injector banks
3 ignitor wires
tps
water temp
etc
Not sure if the link has fuel pump wire for the circuit opening relay, I would try to run that for safety.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby thaphatty » Thu Mar 22, 2007 1:37 pm
Well, this may be no help but i'll post anyway incase overlooked.
aw11 gze w/afm
http://www.club4ag.com/faq%20and%20tech ... 4A-GZE.htm
AE92 USA man trans gze w/afm pinouts
http://home.clear.net.nz/pages/phil.bra ... 20Pins.htm
thaphatty
Postby IH8TEC » Thu Mar 22, 2007 4:14 pm
thanks thaphatty, that will help alot.
dylan, i'm running the g3 with the upgraded internal 55psi map sensor, and also changing to evo 1 coil packs and ignitor.
there are going to be a bucket load of unused wires, ie all the aircon, afm, ignitor, the knock sensor wont be used as i'm under the impression the link wont need it/or recognise it, and like you say the diagnostics wires
plus i'm adding in the wires for tvis as i'm putting that on.
i am wanting to shorten some wires ie the alternator wires as they normally go across the inlet mani and across the head and all the way down to bottom of the engine originally. but not it's at the back, so the cable is really long. i also want to hide or at least tie my gauge wires into the loom so it's not all messy.
knowing this, would it be easier to make a new engine loom? but then which wires to i need to retain for all the internal stuff to work. i'm just thinking for deanis's sake, lol. or i guess it will just mean more beaverages :lol:
cheers for your help
brendon
Postby big_boy » Thu Mar 22, 2007 4:18 pm
i have dash harness pin outs if that helps but have no scanner so il have to send them to you if you want them
for sale EE90
big_boy
Postby IH8TEC » Thu Mar 22, 2007 4:20 pm
for my car? yeah i'd be keen for a copy, have you got a digi cam to take a photo? or just easier to send. pm me :D
