gt 28 turbo on 4 agte
Postby trdfxgt » Thu Mar 22, 2007 3:05 pm
who out there has done this and wants to share there results ? i am doing this upgrade and would like to know what sort of power i can aprox achieve i have a 4 a gze with blue top cams i am well aware that results may differ but just to give me an idea as i am exited about the prospects
when i think of something witty ill put it here
trdfxgt
Postby IH8TEC » Thu Mar 22, 2007 4:38 pm
what else is done to it? what computer etc. can make a huge difference. just be a little more specific
Postby diss7 » Thu Mar 22, 2007 5:37 pm
FYI I have a GT28R and its 230 - 240rwkw capable. And on a 2litre I have no lag, literally none. Making positive boost at 1500rpm, and doesn't taper off, far less lag then I had with a stock t28, and a lot more power
Good turbo for a 4age IMO.
diss7
Postby escortman » Thu Mar 22, 2007 7:37 pm
yeh im using a gt28 now as well cept the one with biggest front housing is it the rs version or something and cant go wrong with real garrett bb
4x4 toyota blizzard offroader
escortman
Postby trdfxgt » Thu Mar 22, 2007 8:02 pm
its running a link v3 and has blitz boost control digital
ps anyone know if i can run launch control with my v3 link
trdfxgt
Postby Caveman » Thu Mar 22, 2007 8:09 pm
Good turbo but in that range i'd consider a td05 for $800 brand new, proven dyno results on heaps of 4ages. Possible 200kw+ at the wheels.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby trdfxgt » Thu Mar 22, 2007 10:32 pm
allready had a nissan flange on my manifold plus i got it at cost for 1000 brand new incl all oil fittings gaskests and water fittings :lol:
trdfxgt
Postby ~SlideWays~ » Fri Mar 23, 2007 10:31 am
I ran one for a while till it failed lol
Was a 8:1 4agze bigport with linkplus tuned by Speedtech.
150kw's atw on 13psi. Standard injectors limited it to that figure. I found a problem with my wastegate after the tune though so 150kw is conservative.
Once IGN timing was right it spooled very well (for a low comp setup) and didn't taper off at all at redline.
Have dyno graphs somewhere. used to be hosted on another site but its been closed since.
~SlideWays~
Users browsing this forum: Google [Bot] and 1 guest
