BZR springs to BZ carib
Postby BzzzzR » Sat Mar 24, 2007 8:39 pm
Hi all
I have just put some new 16" on the carib but due to the soft suspension on the back Im getting a bit of scrub on the out side of the guard my question is will my old standard springs from my BZR fit in to the carib as they are a bit firmer and should fix the guard vs tyre problem ....OR do I need to get new shocks
J
BzzzzzzzzR
BzzzzR
Postby bluemaumau » Sun Mar 25, 2007 12:36 am
have you rolled your gaurds?
Postby BzzzzR » Sun Mar 25, 2007 9:51 am
Yip guards have been rolled this helped a bit ..But the main problem is the soft springs and shocks so when i go around a corner under load it rubs or if I hit a bigish bump ....
BzzzzzzzzR
BzzzzR
Postby bluemaumau » Sun Mar 25, 2007 12:50 pm
what offset are the wheels? shouldnt have much problem with 16s.
what suspension does it have
Postby AceSniper » Sun Mar 25, 2007 4:18 pm
Its way the rear guard is on a carib, the rear springs need to be near stock high but stiffend.
I have a set of teins that are ment for a carib, I fitted into my Trueno, the rear set Lifted the car over the stock springs while the front droped right down. Iv sold them to a carib owner that has the same issue as you.
The BZR springs will fit but due to the mounting/guard hight and the extra weight in the rear they probibly wont help you. best bet is to go aftermarket ones that are made for the carib/wagon
AceSniper
Users browsing this forum: Google [Bot] and 2 guests
