Can someone give me some advise on upgrading my stock intercooler. I'm trying to avoid spending too much, maybe something second hand off a RX7 bat? My MR2 has a 3inch exhaust from turbo and a boost controller running at 14PSI (ish
Thanks.
Nick_MR2 wrote: Do I need this with just the exhaust upgrade and boost (17max). To get 300hp I guess I will need to do someting with the fuel supply - injectors and pump?
Gonad wrote:I could be wrong - but my 205 WTA needed modification to bolt to GENII as the pipe that goes to turbo comes off at different angle and thus the pipe to TB needs to be shifted over a bit. I guess the moved to placement of the turbo on the 205 over a bit?
ST185RC one will bolt straight up however, hardest bit will be mounting the radiator and installing miles if pipes.
Al wrote:Don't mislead the poor fellow into thinking fitting a st185rc or st205 w2a is easy, you haven't even begun on how or more importantly where to fit the heat exchanger.
Anymore and prepare to spend $3k+
