skoty wrote:Big end bearings on the way out...![]()
I remember when I destroyed my big end bearings on my 4age. Intially didn't make a sound when the engine was cold (oil was thick) but progressivly became louder as the oil beacame thinner. And yes it did sound like the noise was coming from the head but I was mistaken when I dismantled the bottom end.
KinLoud wrote:Don't drive it, until it is fixed... you MIGHT get away with just new bearings.
If you keep driving it you will have to replace the crank and a rod and bearings.... and maybe the block too if it throws a rod.
Ken
Ham
021 408 863
big_boy wrote:can you do the work or do you have to pay some one to do it
slighty_sykotic wrote:big_boy wrote:can you do the work or do you have to pay some one to do it
Case of if you have to ask, you probably don't know how.
Guess a better question would be do you want to learn to do it or pay someone...
If you learn to do it, probably looking at:
Big end bearings ~80-100
Plus some gasket goo for the sump. New oil, new filter.
Can get away with doing it in the car, dropping off sump, undo big ends, slide piston up bore, new bearings on, bolt back together. repeat 3 more times. then goo up sump and botl on.
Or if your paying labour, add hundreds.
--Sykotic
Cokeman wrote:skoty wrote:Big end bearings on the way out...![]()
oh tru that sucks then, so it can still be driven but will die soon? I guess if its the big end im gonna havta start looking for another engine?
