Black top 4AGE compression.
Postby ke25sr » Tue Mar 27, 2007 2:19 pm
I need to no how much compression a good blacktop has.
I dont mean 11-1. I want to no the psi reading from a actual test.
Can any 1 help?
ke25sr
Postby sergei » Tue Mar 27, 2007 3:24 pm
The compression ratio has little to do with compression test.
It is all dependant on piston ring and valve seal, and cam timing.
Generally a healthy 20v would produce somewhere around 14bar.
Postby Lloyd » Tue Mar 27, 2007 6:49 pm
As long as they're all pretty even and at least 180odd you should be right
Postby ke25sr » Tue Mar 27, 2007 6:52 pm
I want some one to confirm that they have tewsted a blacktop and tell me the reading they got.
If possible
ke25sr
Postby Logan » Tue Mar 27, 2007 10:02 pm
I compressed tested mine when i got it from the importer, at 140psi on all four. after a short run it was 220 odd i think, but my gauge is very dodgy and doesnt zero it goes back to about 20 (but it still think it reads ok up top)
Not much help but a little indication,
SR Sold. Onto Other Things
Logan
Postby ke25sr » Tue Mar 27, 2007 10:47 pm
I got 190 on all four but the engine is very smokey. Oil pressure is still damm good.
ke25sr
Postby big_boy » Tue Mar 27, 2007 11:01 pm
oil going down the intake stem seal when its open & then burning?
dont know how you would test that tho
for sale EE90
big_boy
Postby ke25sr » Tue Mar 27, 2007 11:04 pm
Allways possible and easy enought o fix.
ke25sr
Postby big_boy » Tue Mar 27, 2007 11:09 pm
check you PCV valve first seen that on a 12R you wouldent beleave how much oil thoes things can let thro
for sale EE90
big_boy
Postby ke25sr » Tue Mar 27, 2007 11:17 pm
Dont think its hooked up on this engine has a catch can for all breathers
ke25sr
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
