Well, I've got a '87 levin, standard 4age engine (assuming TVIS is standard). Had the car for a couple of months now, and since three days ago the engine has sort-of been cutting out on me, especially under acceleration. Very much like what I guess pinking is like. i.e. accelerate> car shudders> hear change in exhaust pressure.
It does not happen every time I accelerate, or when I'm accelerating at all. Sounds a bit like a rotary at idle (for a second or two) every now and then, too.
The problem (probably coincidently) co-insided with a petrol fill up of 95.
I have run the car on 98 (I hope now that the engine can handle 98. Someone please tell me it was perfectly safe to do so!).
At first I just thought that I may have clogs in the fuel feed starving the engine, so gave the car bit of a decent thrash to flush the problem out. No luck there.
It was obvious that the car would not always accelerate as well and the engine tone again was not consistent.
So could this just be bad fuel, or something my poor self needs to see a mechanic about?
Thanks for any help after reading this noob explaination.
PS surely it cant be pinking on 95 can it?
