92mr2paddy wrote:hi, im thinking of putting a fuel reg on my mr2 turbo as well.. if i install a fuel reg will that increase the potential of the standard injectors?? or will i still need bigger injecters (going to run a highflowed ct20b)
RedMist wrote:Dont they run a rising rate FPR stock? (its been a long while since I've touched a bluetop or redtop bigport). IE putting a single rate FPR will screw the maps.
upgrading teh fuel pressure reg to a better quality one gives you better fuel control92mr2paddy wrote:ok, when i get all this set up going i will be running a Link G3 anyway, i want to stay away from changing the injectors since they around 600-800 themselves. so the fuel pressure reg is the way to go if upgrading the system with a link comp and ct20b?
fivebob wrote:RedMist wrote:Dont they run a rising rate FPR stock? (its been a long while since I've touched a bluetop or redtop bigport). IE putting a single rate FPR will screw the maps.
No, they run a fixed pressure differential regulator. i.e. fuel pressure is always the same amount above manifold pressure. Rising rate regulators are a PITA to tune and I don't know why anyone would want to use them.
RedMist wrote:So the fuel pressure rises and falls with manifold pressure? The ECU is expecting this change in pressure? So by fixing the fuel pressure, you're screwing the maps?
fivebob wrote:I don't know of any FPR's (except extremely cheap ones that no one in their right mind would use) that don't have a manifold pressure reference.
RomanV wrote:fivebob wrote:I don't know of any FPR's (except extremely cheap ones that no one in their right mind would use) that don't have a manifold pressure reference.
Mine doesnt!
Standard toyota gen 4 3S.
My FPR has a 'vaccuum' hose coming from it, but it doesnt actually connect onto the manifold where there's vaccuum... it connects onto the throttle body, strangely enough.
I asked a few other people with the same engine to check, and it's definitely like this from factory... There's nowhere else for it to go!
Mine doesnt!
vvega wrote:just for intest..if tuning via tps its adviced to just run a base pressure
fivebob my iunderstanding is that any fpr that changed pressure is rising rate
just some have a different ratio i.e 1:3 1psi of mani presure = 3psi od fuel pressure....vrs 1:1 1psi of boost for one psi of fuel pressure
certanly aeromotive call there 1:1 versions rising rate as well
N/A cars dont need to have then david
