flywheel weight?
flywheel weight?
Postby IH8TEC » Wed Apr 11, 2007 7:45 pm
hello all, i'm just trying to figure out what the factory flywheel weight is for a 4agze one. i know mine has had a bit taken off a few times, so just trying to figure out how much. it's out of a ae92 afm 4agze. as i beleive the ae101 flywheels are slightly bigger?
just weighed mine and it's 5.56kg. if you can get to 2 decimal places would be good
tried searching on google, and here, and club4ag etc, but couldn't find anything, seems to be more on the 4age ones.
thanks
brendon
Re: flywheel weight?
Postby matt dunn » Wed Apr 11, 2007 8:22 pm
IH8TEC wrote:hello all, i'm just trying to figure out what the factory flywheel weight is for a 4agze one. i know mine has had a bit taken off a few times, so just trying to figure out how much. it's out of a ae92 afm 4agze. as i beleive the ae101 flywheels are slightly bigger?
thanks
brendon
Weighing to two decimals is fine, but for it to be that accurate you really need to measure them both on the same scales.
What did you use to weight it?
Postby IH8TEC » Wed Apr 11, 2007 8:26 pm
good point, on the scales at work, they get calibrated monthly. in that case, does anyone have a factory ae92 afm 4agze flywheel in auckland that hasn't had any machining, that i could borrow.
Postby bluemaumau » Wed Apr 11, 2007 8:47 pm
i have a ae92 one at home, on the floor, but no scales. you can come weigh if its critical
Postby IH8TEC » Wed Apr 11, 2007 8:49 pm
you mind if i come borrow it for a day? so i can weigh them on same scales? do you know if it's had much machining done to it? or any
Postby bluemaumau » Wed Apr 11, 2007 8:51 pm
yea you can if you want, pm me
i have no idea. i never gave it a skim
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
