big_boy wrote:according to the rules about it they must be drilled before use as when they have be hot it weakens them if they are drilled also the new stud holes must be atleast 12.5mm away from the old ones or the edge & the bore in the centre must be correct for the hub or adquate sopport must be supplyed for the disk when a support is being used for the disk this support must be the same support that is being used by the rim & must be out of high quilty steel & of adquite depth to support the rim & disk fully
Ae92typeX wrote:not saying you are wrong, but I know quite a few guys in aus re-drilling used disks. Would have thought they would have a rule like that before us...
anyone got a link to site to confirm?
