AE92blktop wrote:Both motors are in very good condition with the gze having done less than 80,000 so thats good to hear, I was thinking gze bottom blacktop head with a good clean up, i have the g box from the aw11 as well which i hear can be made to fit a fwd application as for the turbo i have been told a td05? or a subaru turbo works well (i will look further into it before deciding). Can you get a computer with a 4agte base map as I would like to wire it and get it running myself then get it fine tuned?
narlystarly wrote:As per above, 170 is very doable. Dont even need big t3/t4 as someone said. ht18/rb20exhaust turbo will make 195 as per my sig
Crampy wrote:narlystarly wrote:As per above, 170 is very doable. Dont even need big t3/t4 as someone said. ht18/rb20exhaust turbo will make 195 as per my sig
That's the same turbo I've got for my 4AGE. I'm going for lower boost than that though (I'll have a fuel cut at 15psi). Any idea on how much power it'll make with say 7psi and how much at 15psi?
Cheers.
Cheers.
IH8TEC wrote:Crampy wrote:narlystarly wrote:As per above, 170 is very doable. Dont even need big t3/t4 as someone said. ht18/rb20exhaust turbo will make 195 as per my sig
Cheers.
bugger all, put more boost in it cramps
narlystarly wrote:think i made 165 on 14-15psi, something like that, will try find dyno plots.
