hey guys, hypothetical question. two identical engines, one with a supercharger setup, with water-air i/c, one without. compression the same, etc. how much difference in the performance of the engines would there be if the supercharger was freewheeling? would the supercharger create much of a restriction on the intake?
for example, two silvertops, both running link ecus to control a/f, compression, pistons, exhaust, etc, all the same, only difference being one has gze s/c setup. if the s/c is turned off, would both setups perform the same in the same car? i know that with the 4agze that if you turn the s/c off it is pretty gutless, but is that more due to the engine being setup for forced induction and it not boosting, than the restriction of the extra items in the intake path?
yeah i know, probably confusing as hell, lol, but any help would be great.
