4agze ecu with turbo ? is it doable or better avoided?
Postby jdm 102 » Tue Apr 24, 2007 12:00 pm
"I think your research is wrong, but go right ahead. I think it will never be as nice a car with a turbo on it. The stock ECU does not have the correct fuel or timing maps for a turbo, which puts totally different demands on the engine."
Is what a mechanic (whom I've been intouch with regarding whether to go SC14 or Turbo) , thats what he said to me when I said of turbo on the stock ecu (well to start it up, a t28) mind you I plan to run it on stock ecu for about 2 months til which time I could afford a decent ecu, just that doing one big hit $$ doesn't suit myself lol..
what does the community here say? because I'm sure I've read about stock ecus on the gze running turbo at about 12psi.
jdm 102
Postby bluemaumau » Tue Apr 24, 2007 12:39 pm
obviously itll never run as mint as it would on a aftermarket system, which imo you should just bite the bullet and get.
afaik afm gzes can go to 16-18psi, but are leaning out at that stage,
itll run, just depends how well and what damage is being caused
Postby evil_si » Tue Apr 24, 2007 1:57 pm
they are fine and run sweet,
if you want more boost better to go aftermarket ecu,
standard fuel gear and map ecu tend to max out at 11-12psi depending on your turbo, as ,long as you upgrade the fuel system, bigger pump and injectors you shud be sweet,
evil_si
Postby Crucible » Tue Apr 24, 2007 2:17 pm
yeah it will be sweet....
Had my fuel checked on the dyno with stock e.c.u and it was a little lean down low upto 8psi, but then it started richening up the a/f after that. I ran it for months on end Turbo, with a high setting of 11-12psi and had no problems at all. Drove it fairly hard aswell...
like Simon says if you want to get rid of the restrictions and want more boost which I guarentee you will!, aftermarket e.c.u and a good tune.
Crucible
Real Life Mechanic
Postby Caveman » Tue Apr 24, 2007 2:51 pm
I ran stock ae101 computer on a 4agte for a while
made really good power, stock ecus have a few problems with faulty knock control which stunted mine a bit (uncommon). I was running 11:1 @ 9psi boost throughout full RPM with standard reconditiond injectors.
No modifications needed on the computer to run the turbo. As TNT said just check the A/F ratio, use an adjustable fuel pressure reg if you want to modify a/f without changing to aftermarket computer.
AW11 Track Toy
Formerly known as 1998
Caveman
