coil packs for a 4age redtop small port
Postby westwayz » Wed Apr 25, 2007 12:11 pm
is there any thing out there? thats "plug in" i have a link and have been told i should go coil packs.
[ KE70 - 20v Dori'O Machine ] - In the build
westwayz
Postby AceSniper » Wed Apr 25, 2007 12:21 pm
mitsi 4cyl coil packs and igniter
AceSniper
Postby westwayz » Wed Apr 25, 2007 2:56 pm
AceSniper wrote:mitsi 4cyl coil packs and igniter
do i need a CAS? wat do i get that off?
westwayz
Postby bluemaumau » Wed Apr 25, 2007 4:11 pm
4agze
Postby AceSniper » Wed Apr 25, 2007 8:34 pm
4agze igniters wont work on a link, but the coils will so if u use 20v leads u could use them with a mitsi or link igniter.
you wont need cas as your link will be using the cas in your dizzy so you need to keep the dizzy there, just any mitsi that has coil packs and is 4cyl get the igniter and coils inc plugs
AceSniper
Postby westwayz » Thu Apr 26, 2007 11:38 am
AceSniper wrote:4agze igniters wont work on a link, but the coils will so if u use 20v leads u could use them with a mitsi or link igniter.
the reason is i want to get rid of the dizzy all togeter but i spose its a start and until i can find a cas wel...
westwayz
Postby sergei » Thu Apr 26, 2007 11:42 am
you can make CAS out of your 4AGE distributor, internally (as in triggers) it is identical to GZE CAS, what you need to do is to remove the high tension distributor part and make a cover for whats left.
Postby westwayz » Thu Apr 26, 2007 8:13 pm
sergei wrote:you can make CAS out of your 4AGE distributor, internally (as in triggers) it is identical to GZE CAS, what you need to do is to remove the high tension distributor part and make a cover for whats left.
sweet :mrgreen:
westwayz
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
