18 -> 20 mm gudgeon?
Postby Chickenman » Wed Apr 25, 2007 9:22 pm
Can a piston with an 18mm gudgeon be taken out 2 mm and still maintain it's structural integrity?
Got some ACL pistons for bluetop today and don't quite know what I'm going to do with them :lol:
Baby Jesus
Chickenman
I Am The Walrus!
Postby Mr Revhead » Wed Apr 25, 2007 9:53 pm
lol u should be able to get them machined
best ask engine builders about it
Postby Chickenman » Wed Apr 25, 2007 9:56 pm
I'm just asking if it's a good idea or not :?:
Baby Jesus
Chickenman
I Am The Walrus!
Postby Mr Revhead » Wed Apr 25, 2007 10:12 pm
if the construction of the piston allows it, then yeah why not
if they suit your needs
i think the tricky bit could be the circlips
Postby Chickenman » Wed Apr 25, 2007 11:11 pm
I think I'll buy a bluetop :idea:
Baby Jesus
Chickenman
I Am The Walrus!
Postby Bling » Wed Apr 25, 2007 11:47 pm
you can buy my bluetop :wink: :lol:
Postby atmosports » Thu Apr 26, 2007 9:12 pm
Either Circlips or Spiralocs should be easy to get for 20mm gudgeons. Machining for them is easy if your used to machining pistons & isn't really any harder to do than any other circlip or internal groove.
atmosports
Postby Mr Revhead » Fri Apr 27, 2007 9:48 am
there ya go chook.... send em north :twisted:
Postby Chickenman » Fri Apr 27, 2007 10:04 am
I don't think it's worth it at the end of the day. Will just keep them hanging around until I find a use for them.
Baby Jesus
Chickenman
I Am The Walrus!
Postby atmosports » Fri Apr 27, 2007 9:45 pm
There are plenty of competent people in the South Island around Christchurch/Timaru that could do them for you I'm sure, if there is enough meat round them. I haven't got this exact set sitting in front of me to know & I'd rather try & persuade someone to buy a decent set of pistons like a set of CP's than machine something to do the job as I have seen some JE's fail through the gudgeon boss under heaps of boost & it wasn't a pretty sight.
If you get stuck for circlips/lock try Proturn Engineering(Dick Chapman used to be LR Race components) or Denco(Bob Benson) both manufacture pistons & have done so for many years & had a pretty good selection or will be able to point you in the right direction. Else I have had luck with Sydenham Park(Silvesters), Kelfords,Segedins etc as well in trying to source enough for one piston or odd sizes.
atmosports
