Ignitor wiring...4age late model bigport
Postby no_8wire » Wed Apr 25, 2007 10:37 pm
Well I need to wire in a sr20 ignitor so I can use it for the link im going to be running.
But first I need to know what the factory ignitor wires are, earth power etc...
Heres a pic.
Can anyone help?
no_8wire
Postby no_8wire » Sat Apr 28, 2007 6:45 pm
:arrow:
no_8wire
Postby Zak » Sat Apr 28, 2007 7:44 pm
viewtopic.php?t=29954
I think most of the colours should be the same, just one out put and no toggle.
Zak
Postby mr30%jr » Sat Apr 28, 2007 8:56 pm
most colours wont apply till there in the engine loom
in most cases pinouts looking like this from the ignitor side of the plug with pins towards you READING RIGHT TO LEFT! FROM TOP
1 IGF ignitor fired (Black yellow)
2 IGT ignitor fire (Black white)
3 B+ POWER FEED > to EFI MAIN RELAY (black red)
4 TACHO (black)
COIL should be on its own feed
mr30%jr
Postby AceSniper » Sun Apr 29, 2007 1:03 pm
brown as always = ground
AceSniper
Postby no_8wire » Sun Apr 29, 2007 1:23 pm
nope. in this case brown/tan is the 12v feed.. :lol:
But I have it sorted now anyway...
no_8wire
Postby AceSniper » Sun Apr 29, 2007 2:05 pm
damn aws
AceSniper
Postby matt dunn » Mon Apr 30, 2007 9:46 pm
have you pulled the igniter apart to expose those wires?
That eye looks like it's meant to be earthed into the case.
Cant tell from there but they are usually labelled on the underneath of the moulded plastic plug from factory without disassembly.
Postby no_8wire » Mon Apr 30, 2007 11:00 pm
yeah pulled it apart, as I was going to use a sr20 ignitor...
no_8wire
Postby matt dunn » Mon Apr 30, 2007 11:17 pm
then the moulded part just out of the pic should have some abbreviations on it. post them up and I will tell you what they mean.
