l1ttle_d3vil wrote:its not only the waterpump you have to change.
if you want rwd waterlines you have to use:
* rwd 3a/4a waterpump housing (has thermostat housing at the rear)
* rwd 4a waterpump pulley (has different offset to the fwd pulleys)
* rwd 4a alternator mounts (fwd alternator mount sits the alternator too high so it hits the thermostat housing when using rwd w/pump housing)
everything else can be fwd (crank pulley, alternator, waterpump itself)
Zak wrote:Mostly right, but you have to use the same pully AND water pump, so if he's putting the RWD in use the RWD pully, or vise versa. Also, if you use a FWD pump, don't use the fan or it's wreck your water pump bearing in no time.
fxgt race wrote:have the pump with thermostat housing on rear,and have another pulley that is a single v belt pulley or is the 4a pulley a 5v belt one
