Triple plate clutches
Postby Emperor » Fri Apr 27, 2007 7:27 am
I got a new RX7 on the way from Japan (old one should be sold soon), 1992 S6, will be turned into a Pro 7 car.
Putting a new engine in (brand new), and also clutch and flywheel. Got flywheel sorted, but need to decide on a clutch.
Are there any that anyone would reccomend? Dad said his one is the best he's ever used, grabs instantly and doesnt slip at all, but he doesnt know what it is lol
Is Exedy any good?
Emperor
Postby Dell'Orto » Fri Apr 27, 2007 11:50 am
Why would you want a triple plate? Pro 7 plus cars dont make that much power. Exedy do quite good clutches, or there are a number of clutch outfits in Auckland who can custom build one to suit.
Postby Lith » Fri Apr 27, 2007 12:58 pm
Exedy are the highest used as OEM clutch manufacturer in the world AFAIK, so can't be too bad. Quartermaster make reasonable priced and pretty good twin plates - I've driven a FC3S running one at it was quite usable. As Mmm, Boost said - I don't know why you want a triple plate for a lowish power circuit car. A twin plate could be handy I guess, they bite REAL quick when you want them to.
Lith
Postby Emperor » Fri Apr 27, 2007 6:21 pm
Mmm, Boost wrote:Why would you want a triple plate? Pro 7 plus cars dont make that much power. Exedy do quite good clutches, or there are a number of clutch outfits in Auckland who can custom build one to suit.
240hp, not that low. But comparing dads old setup with single plate, didnt launch as good as the triple plate guys
Emperor
Postby Dell'Orto » Fri Apr 27, 2007 6:58 pm
240hp is less than a stock FD3S, and they do quite fine with single plate clutches.
Twin plate would be more than adequate...try Quartermaster as Lith mentioned, they do quite good units.
Postby Bazda » Fri Apr 27, 2007 8:24 pm
QM twin plates, very nice. What i run 8)
will set u back about $1400-1500
Postby method » Sat Apr 28, 2007 12:18 am
Quater master arn't that good.
Ive heard bad stories a few times to do with quatermarster clutches.
Go for a sports tuff excedy.
PICS UPDATED DAILY
method
Postby Bazda » Sat Apr 28, 2007 1:24 am
method wrote:Quater master arn't that good.
I know those stories about stripping the inner splines on the plates but they arent like that anymore.
If they werent that good the Nascars wouldnt be using them
Postby Emperor » Sat Apr 28, 2007 1:55 am
Mmm, Boost wrote:240hp is less than a stock FD3S, and they do quite fine with single plate clutches.
And correcting my last post, dad had a twin plate, and the difference in launches was way better with the triple. Only bad thing with the triple is trying to drive it round the pits.. Impossible lol
Yeah heard good things bout Exedy, most of the Pro 7 guys use them, but wanted to know if there was any other good brands to try that arnt a bad price.
Emperor
Postby AJz » Sat Apr 28, 2007 2:01 am
im guessing NA then like the last one if its 240hp ???
I had vtax :(
AJz
Postby Emperor » Sat Apr 28, 2007 11:35 am
AJz wrote:im guessing NA then like the last one if its 240hp ???
Yes, like every other pro 7 car is too. :)
Emperor
Postby Bazda » Sat Apr 28, 2007 11:47 am
I found launches were worse with the twin plate as it just grips instantly and spins the wheels. I found a little bit of slip is better
Postby Dell'Orto » Sat Apr 28, 2007 2:10 pm
You using a Renesis engine or de-turbod 13B REW?
Postby Emperor » Sat Apr 28, 2007 10:49 pm
de-turboed 13B REW. but tuned properly,a brand new engine. with series 5 intake manfild (shorter for quicker air intake)
Emperor
clutch
Postby catchafox » Sun Apr 29, 2007 11:09 pm
ive got an os gieken twin plate for sale if your keen 0212129628
catchafox
Postby Dell'Orto » Sun Apr 29, 2007 11:23 pm
Surely the renesis motor would be a better option? And wouldnt an FD intake give better torque?
Postby Emperor » Mon Apr 30, 2007 7:57 am
Mmm, Boost wrote:Surely the renesis motor would be a better option? And wouldnt an FD intake give better torque?
Nope, after dyno + track testing, S5 seems the better.
We're not allowed to use the renesis, they were going to bring it in for the 2008/09 season, but its now been pulled out for "review at a later date".
We're allowed renesis rotors
Emperor
Postby evil_si » Mon Apr 30, 2007 9:46 am
in my series 6 ive got a HKS twin plate and cromolly flywheel, wont slip but is a bitch to drive with
evil_si
Postby Emperor » Mon Apr 30, 2007 6:19 pm
evil_si wrote:in my series 6 ive got a HKS twin plate and cromolly flywheel, wont slip but is a bitch to drive with
how much and where from
Emperor
Postby Dell'Orto » Mon Apr 30, 2007 7:19 pm
Interesting, though I guess NAQ applications are gonna require totally different to turbo ones.
Geez I'd hope you're allowed Renesis rotors, low comp NA 13B FTL :lol:
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
