Rear Sway Bar Q
Rear Sway Bar Q
Postby rolla_fxgt » Tue May 08, 2007 3:44 pm
Anyone know the diameter of a standard rear sway bar in an Ae101 FxGT?
Reason i ask is mine has stuffed bushes & i need new ones, nolathane (sp) list 3 sizes, 15, 17, & 22mm & i wanted to find out without having to get under there with a measurer.
Much appreicated if anyone knows
rolla_fxgt
Postby 4-AGE 4-LIFE » Tue May 08, 2007 5:29 pm
well we list a 14mm and 16mm at work for them, im pretty sure they came out with 14/15/16 mm bars, best way is to check it im sure u can reach the swaybar by lying under the back with a set of verniers.
Ben Threadwell
Exsus Automotive
Suspension specialists
4-AGE 4-LIFE
Postby BigDon » Tue May 08, 2007 8:20 pm
Non superstrut FXGT ae101 front is 25mm and rear is 16mm factory.
If your really want it to behave nicely then get some of these to go with the new bushes.
TRD front sway bar 28mm, 57% higher spring rate
TRD rear sway bar 19.1mm, 27% higher spring rate
www.europeandirect.co.nz
1996 AE111 BZ-G: TRD equipped road legal Club Car (Manfeild 1.25s) (SOLD)
1995 AE111 BZ-G: Stereo and daily driver (SOLD)
2005 NZ New Evo 9 GT (specd to FQ360) daily driver
2012 NZ New Outlander VRX - V6 family wagon
BigDon
Postby AceSniper » Tue May 08, 2007 8:47 pm
non s/s
Rear 16mm
Front 25mm
s/s
18mm rear
24mm front
urathane bushes : rear bushes nolathane do, front bushes superpro do,
Whiteline do a 18mm rear bar that adjusts upto 22mm
AceSniper
Postby neo » Tue May 08, 2007 10:32 pm
AceSniper wrote:Whiteline do a 18mm rear bar that adjusts upto 22mm
I had issues with the swaybar fowling on the inner arches on my 101 fx, on the 22mm setting, so really its just 18-20mm =)
neo
Postby AceSniper » Tue May 08, 2007 10:41 pm
weird, dosnt in my trueno
AceSniper
Postby Mr Revhead » Tue May 08, 2007 10:50 pm
yeah appears to only happen to those ghey fxgts :twisted:
Postby rolla_fxgt » Wed May 09, 2007 10:43 am
Cheers guys thanks for all your help, much appreciated!
I would buy a complete whiteline or trd bar setup but i've worn out a rear control arm & revhead tells me toyota haven't had to get one in before so i'm waiting for the cost of that, which i expect to be not cheap 8O
rolla_fxgt
Postby AceSniper » Wed May 09, 2007 2:37 pm
why not grab one from a wreaker?
AceSniper
Postby rolla_fxgt » Wed May 09, 2007 3:55 pm
I did last time for the rear trailing arm, this is the 2nd one i've worn out in 6 months 8O
So trying buying new & then if it breaks again soon i can ask toyota nicely for a new free one that wont break :P
And for the sway bar nolathane bushes are pretty cheap anyway, execept front ones which they dont make because they're a strange shape apparently
rolla_fxgt
rolla_fxgt
Postby Mr Revhead » Wed May 09, 2007 6:25 pm
sounds like you may have a deeper issue there
Postby AceSniper » Wed May 09, 2007 6:59 pm
superpro make them for the front
AceSniper
Postby rolla_fxgt » Thu May 10, 2007 11:19 am
Mr Revhead wrote:sounds like you may have a deeper issue there
Any ideas what else i should look out for that may be causing this issue when i've got it up on the lift?
At that price dont really want to be replacing them every 6 months, its not so good for the saving s account balance
rolla_fxgt
Postby Mr Revhead » Thu May 10, 2007 9:33 pm
bent stuff....
look for things that are stressing that point.
its not a common thing for them
