Mr Revhead wrote:tigging the arms will heat some sections quite a bit, iv been told that after welding the entire arm should be heated then left to cool very slowly to "normalize" it and relieve stress points.
why not use the AA63 arms as well?? they are a sh!tload longer than KE70Mr Revhead wrote:am fitting aa63 front struts
those struts give positive camber with the stock ke70 lower arm
id be keen on more specific info on those mitsi arms.....
camber plates?Mr Revhead wrote:because i dont have them
i also need some form of camber adjustment, so id have to cut them up as well.
can i expect ' how much can you bend an axle tube before the axles fully bind?' as your next offering?Mr Revhead wrote:just wait till u see the camber on the rear!!
fangsport wrote:can i expect ' how much can you bend an axle tube before the axles fully bind?' as your next offering?Mr Revhead wrote:just wait till u see the camber on the rear!!
