And is there any place that would be recommended to go to for changing clutches in Auckland?
sergei wrote:Take the flywheel off and change rear main seal, also changing drive shaft seals would be good idea too.
Alycia wrote:sergei wrote:Take the flywheel off and change rear main seal, also changing drive shaft seals would be good idea too.
Be warned, those flywheel bolts are usually nice and tight - Powerbar and extension bar tight
Cicak wrote:Where would it be the best place to get the seals and bearings? Toyota? or aftermarket brands?
JT wrote:Cicak wrote:Where would it be the best place to get the seals and bearings? Toyota? or aftermarket brands?
Mr Revhead, genuine toyota parts. Don't bother with 'aftermarket' seals and bearings.
pc wrote:And obviously new thrust bearing and pressure plate.
Maybe do gearbox fluid at the same time as it probably hasn't ever been changed... then you'll always remember when it was done
Adydas wrote:pc wrote:And obviously new thrust bearing and pressure plate.
I did this, and it caused my good syncros to become crunchy, in my case it was the " if its not broken dont fix it " thing.
