AE86. Bent axle and replacement questions.
Postby Stealer Of Souls » Mon May 14, 2007 3:27 pm
I have a suspected bent axle in my "T" rear end. Or more precisely it's 99.9% sure it's bent. Anyway.
Worn diff bits mean I'm taking the diff out and subsequently the axles are getting taken out too. I'm going to replace the bent one, the question is...
Would you replace both of them given their age, and the condition of one of them?
Opinions please...
'86 AE85.5 Levin
Stealer Of Souls
Postby FouRacer » Tue May 15, 2007 10:26 pm
Not absolubtly neccesery but depending on how the first one got bent, the other could have had quite a shock, might pay to get it checked for straightness, and maybe even crack tested, really depends on what the car is bieng used for!
GT-FOUR Racer
FouRacer
Postby Drifter4ag » Wed May 16, 2007 12:56 am
yeah ...
replace it with a hilux diff
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby crispy'86 » Wed May 16, 2007 7:48 am
chances are if one axle is bent what's the diff housing going to be like? check everything for straightness especially the other axle , while they're out it saves alot of messing round after the diff's been out back together just to find the other axle's damaged
crispy'86
Postby Mr Revhead » Wed May 16, 2007 10:17 am
hilux diff no good for racing, unless you spend $$$ on it.
as said, while its apart.... check it
Postby Xylotrope » Fri May 25, 2007 10:16 am
Mr Revhead wrote:hilux diff no good for racing, unless you spend $$$ on it.
. check it
Can you elaborate on this please ..
I run one in an AE86 rally car .. seems ok .. whys it a dud ?
Thanks
"Theology is the effort to explain the unknowable in terms of the not worth knowing"
"If GOD lived on earth people would break his windows"
Xylotrope
Xylotrope
Postby Mr Revhead » Fri May 25, 2007 10:29 am
lack of LSD ramps. so instead of having clutchs and ramps, they just have clutchs
wont be so bad on gravel due to the lower grip levels
but on seal they are known for slipping and spinning one wheel.
Postby NA Drifter » Fri May 25, 2007 11:44 pm
Mr Revhead wrote:lack of LSD ramps. so instead of having clutchs and ramps, they just have clutchs
So, problem solve if track use only when they locked.. ? :P
Keith
NA Drifter
Postby matt dunn » Sat May 26, 2007 10:43 am
Hilux diff + welder = OK,
I run a locked in mine on the circuit.
Dont think you'd want to use a welded diff on the street,
especially in the rain.
Revhead may remember trakling the celica rally car for a ride in the wet with a locked diff....
Postby Mr Revhead » Sat May 26, 2007 11:11 am
:lol: yeah
i also remember my escort
awesome on gravel an absolute #%^&#%& on the road
