Wastegate Vacume
Wastegate Vacume
Postby Go_the_mini » Thu May 17, 2007 6:57 pm
Quick question, have put the new wastegate in and welded up turbo, screamer pipe is on an ready to go just need to sort out the last of my vacume lines. Can anyone tell me where the two vacume lines from the wastegate run? Guessing one must go to the vacume on the top of the turbo that used to run to the actuator, Cheers any sugestions are much apreciated.
Go_the_mini
Postby sergei » Thu May 17, 2007 6:58 pm
For external use bottom one for boost reference and leave top one disconnected. Do not block the top one. Top one is used when you have electronic boost controller.
Postby deaf_rattle » Thu May 17, 2007 7:00 pm
my suggestion
plumb the "screamer pipe" into your exhaust or run it through a muffler.
http://www.sytyarchives.com/howto/viewa ... dir=engine
that may help you however
Postby Go_the_mini » Fri May 18, 2007 4:25 pm
"boost reference" Would that be the hose running off the top of the turbo? Sorry for dumb questions, first turbo car
Go_the_mini
Postby sergei » Fri May 18, 2007 5:34 pm
yep.
