EVL20V wrote:post whore!
barryogen wrote:EVL20V wrote:post whore!
eh? me??? not intentional if thats what you meant.
So, got an OBD II reader? or you just trying to up your own post count...![]()
dick.
EVL20V wrote:as a matter of fact my mate whos an auto electrician has one at his work, hence why i viewed this topic and was making a joke which you obviously didnt see the harmless intent ie:![]()
do you want me to enquire?
pyro_sniper2002 wrote:OBD2 plugs are a standard plug, there for are diffrent to the standard toyota plug. Should be in the drivers footwell above the peddles me thinks.
matt dunn wrote:You realise that actual ODB only relates to emission related faults?
Matt
The program lets you perform the following operations:
* Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
* Clear trouble codes and turn off the MIL ("Check Engine" light)
* Display current sensor data, including:
o Engine RPM
o Calculated Load Value
o Coolant Temperature
o Fuel System Status
o Vehicle Speed
o Short Term Fuel Trim
o Long Term Fuel Trim
o Intake Manifold Pressure
o Timing Advance
o Intake Air Temperature
o Air Flow Rate
o Absolute Throttle Position
o Oxygen sensor voltages/associated short term fuel trims
o Fuel System status
o Fuel Pressure
o Many others...
barryogen wrote:nope, never bothered, have since sold the car and got an altezza with a power FC, andd am tinkering with a bit of software that talks to that that does the same and more.
TWSTD wrote:Might I ask what that software is?
