manifold leak
manifold leak
Postby groupagt4 » Fri May 25, 2007 2:27 pm
the downpipe on my charade turbo is loose where it goes onto the exhaust housing of the turbo,will this cause some Boost leak or the turbo to boost less
groupagt4
Postby sergei » Fri May 25, 2007 2:35 pm
and your question is?
I mean you already answered your question ;)
Postby groupagt4 » Fri May 25, 2007 7:17 pm
soooo yes it will make a difference?
groupagt4
Postby 92mr2paddy » Fri May 25, 2007 7:25 pm
it wont if you just tighten it back up :P maybe some new spring washers and bolts??
if its a bad leak u might not get a warrant.
92mr2paddy
