power and 1/4 mile times
Postby avinesh » Tue May 15, 2007 9:12 pm
QikStarlie wrote:198kw, 12.80 at 188km, 920kg? with me in it
1990 mr2 gtt 13.4 @ 167 km/h ran at 15psi but on dyno had some issues an couldnt boost over 11psi
avinesh
Postby EuroSport » Tue May 22, 2007 1:02 pm
178kw @ wheels (4wd)
1/4 mile 13.4 @ 177km/h
1375kgs + 85kgs for me.
EuroSport
Postby pc » Tue May 22, 2007 4:39 pm
84kw
913kg + 74kg me
15.45s
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Drifter4ag » Sat May 26, 2007 10:18 am
13.1 @ 184kmh 990kg 182kw@wheels - ae86
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby oem-r » Wed May 30, 2007 1:31 am
Can non toyota owners post? :lol:
13.7 @ 165km, 126kw atw, 1080kg plus me 70kg- Integra type r
oem-r performance
oem-r
Postby deaf_rattle » Wed May 30, 2007 9:02 am
subie racer wrote:Can non toyota owners post? :lol:
sure, ill update the first post tonight with the new figures.
Maybe this post could be sticky'd now?
Postby sergei » Wed May 30, 2007 12:09 pm
Oh, My car is 1987 Celica GT4 (ST165).
Postby IH8TEC » Wed May 30, 2007 1:15 pm
ae92 trueno 147kw atw 8) 13.5@174 1200ish incl me
Postby Crampy » Wed Jun 06, 2007 3:33 pm
Done at last winter wars.
Stock AE82 FXGT.
Apparently 960kg + Me 105kg :oops:
17.0 sec @126km/h.
Deanis worked it out on a HP calculator and worked out to be about 83 HP at wheels hehehe. Go the rolla.
ps, You don't have to add that to your list if you don't want too.
Crampy
Postby Lith » Wed Jun 06, 2007 3:39 pm
14.1 @ 165kph at winter drag wars a few years ago, Skyline R33 GTS25t with 183kw @ rears at the time.
Weight is 1370kg + 85 + a bit more = ~1460kg? :)
Lith
Postby Flannelman » Sun Jun 17, 2007 7:59 pm
AE101, 180 000km old unopened engine (4AGE 20V Silvertop). Airbox removed and replaced with pod, large aftermarket extractors, 2 1/2 inch strait thru exhaust with single turboflow muffler. Standard computer. Road tyres, rims...195/60R14
non LSD standard ratio gearbox (158km/h in third), preformance clutch
1025kg with 75kg me =1100kg
dyno 87.5kW@8000
before extractors 78kW@8000
1/4 mile, 15.881 @ 89mph, Run with dirty pod (cost 3.5kW)
before extractors 16.167 @ 142km.
be back with a faster time, as drags have to be consistent
Oh, Reation time .5sec. perfect time is .4 sec
the time starts when the green light goes, sit there for a reaction time of .7, and the car is .3sec slower than it can realy go.
Flannelman
formerly known as Affroman
Postby Crampy » Sun Jun 17, 2007 10:04 pm
The reaction time has nothing to do with the ET. You can sit at the tree for 10 seconds and then do your run and you'd still get the same ET.
Crampy
Postby Mr Revhead » Sun Jun 17, 2007 10:10 pm
that depends on the format of the meet....
Postby Stu- » Mon Jun 18, 2007 7:33 pm
Update mine to 13.02 @ 182kph
Project Thread
Stu-
Postby Lith » Mon Jun 18, 2007 7:58 pm
Mr Revhead wrote:that depends on the format of the meet....
Well all proper drag meets start timing when you cross the start beam. If you didn't, the chaser in DYO would never get realistic times.
Lith
Postby Mr Revhead » Mon Jun 18, 2007 8:42 pm
im used to watching NHRA etc :lol:
times start on the light
Postby fivebob » Mon Jun 18, 2007 9:01 pm
Mr Revhead wrote:im used to watching NHRA etc :lol:
Not on any NHRA meet I've ever watched, time starts when they cross the beam.
I've lost count of the number of times I've seen a lower ET lose the race cause they were too slow off the mark.
Postby Lith » Mon Jun 18, 2007 9:05 pm
http://www.nhra.com/basics/glossary.html
As far as NHRA are concerned - and all other drag racing entities I am aware of:
Elapsed Time: the time it takes a vehicle to travel from the starting line to the finish line. Also called e.t.
You do strive to go for the fastest time to the finish line however, but your ET (what you use for bragging rights) has nothing to do with reaction time.
Snap, fivebob ;) You were just slightly quicker at hitting submit haha.
Lith
Postby Flange » Mon Jun 18, 2007 9:10 pm
standard ae86
16.0 @ 132ish km/h
Flange
Postby Mr Revhead » Mon Jun 18, 2007 9:26 pm
:? i always thought topfuel classes ran to the lights...
otherwise why do RT matter....
i notice that in prostock....
hmmm
Upon leaving the staging beams, each vehicle activates an elapsed-time clock, which is stopped when that vehicle reaches the finish line
well. fancy that :lol: :oops:
