Supercharger Oil
Supercharger Oil
Postby m4vr1k » Sat May 26, 2007 8:03 pm
Hey guys.
Finally got my ass into gear with supercharging my S13.
Fuel system is done (255 lph Walbro pump, SARD fuel pressure reg, S13 SR20DET injectors), just need to plumb the intercooler piping and BOV and im away.
Quick question re: supercharger oil. I was hoping to have the car mostly done tomorrow, and i am pretty sure that checking and adding oil when the charger is on the engine will be a major pain in the ass, is it possible, and worthwhile to use a substitute oil?
Otherwise i have to wait for Toyota to open on Monday, and will be waiting till Tuesday or Wednesday for my oil
Cheers!
Zac
Roses are red
Violets are blue
In Soviet Russia
Silvia Drifts You!
m4vr1k
Postby thegreatestben » Sat May 26, 2007 8:08 pm
Gear oil is ideal. I used some castrol stuff
Here ya go
"Castrol VMX is an advanced technology SAE 80W, mild extreme pressure gear oil with special viscosity stabilisers to overcome cold shift baulk and hot rattle problems in most four and five speed transmissions and light commercial manual transmissions. Castrol VMX is suitable for transaxles of most front wheel drive vehicles fitted with transverse engines. Castrol VMX should not be used in Hypoid differentials.
Meets API GL3 and GL4 performance requirements"
thegreatestben
Postby pjay » Sun May 27, 2007 12:02 am
tgb.mr2 wrote:Gear oil is ideal. I used some castrol stuff
*edit. make sure its really really thin at least. and get the genuine stuff in asap if you care bout your charger.
pjay
Postby m4vr1k » Sun May 27, 2007 9:38 am
Okay, so there are two differing opinions.
Gear oil is hardly thin oil, 80w, quite thick. I would have thought something thin like mobil 1? or that new castrol Edge stuff,
Roses are red
Violets are blue
In Soviet Russia
Silvia Drifts You!
m4vr1k
Postby Mr Revhead » Sun May 27, 2007 10:37 am
the oil in the s/c lubricates two helical cut gears that spin rather fast....
the genuine oil is quite thin. thinner than engine oil.
Postby evil_si » Sun May 27, 2007 10:43 am
just wait for toyota,
holden do some s/c oil as well, i personally wont use it again, had a couple of s/c's blow while using it, never had any issues when using genuine s/c oil
evil_si
Postby m4vr1k » Sun May 27, 2007 10:46 am
yeah, sounds like the best idea, might just have to wait for Toyota to open on monday.
Cheers guys!
Roses are red
Violets are blue
In Soviet Russia
Silvia Drifts You!
m4vr1k
Postby thegreatestben » Sun May 27, 2007 10:47 am
I should've said earlier that I would reccommend waiting for the toyota stuff.
Was just giving you an example of other oil that some people use.
I got the info of a US mr2 board about the VMX and I used it in my car. Was fine.
Hve you checked whether its already got oil in it also. Just that they are a sealed unit and its common to buy 2nd hand ones with oil in them still. Don't want to flood the damn thing :)
thegreatestben
Postby ~SlideWays~ » Sun May 27, 2007 12:06 pm
tgb.mr2 wrote:I should've said earlier that I would reccommend waiting for the toyota stuff.
Yeah I've been using VMX for about 5 years now. No probs.
~SlideWays~
Postby m4vr1k » Sun May 27, 2007 12:40 pm
yeah, ive checked it, its dry as a bone.
I will wait for the Toyota oil, hell, maybe it will be easy to access once all the ancillary crap is back on the engine.
Not working on it today, doing some filming for a movie, will get stuck back into it tomorrow.
zac
Roses are red
Violets are blue
In Soviet Russia
Silvia Drifts You!
m4vr1k
Postby thegreatestben » Sun May 27, 2007 12:47 pm
Toyota stuff comes with a syringe(sp?) Its easy if you do it slowly, cos air has to come out as the oil goes in so don't dump it in other wise it all just pours out.
thegreatestben
