Voyeur wrote: I know that the TPS, and speed sensor have nothing to do with vvt, as when you disconnect them vvt still works. .
Voyeur wrote: The blowby is a good theory as this would alter the manifold pressure. To see if this was true I fitted a restricter in my pcv line last night, and while this helped with low throttle cruising (100 km at 3000rpm ) it made no difference to mid throttle acceleration. Does this give anybody any ideas.
Voyeur wrote:Sorry, i will explain jan 97 blacktop 20v levin, imported ex Tokyo 7 month's ago. Factory engine except it has a piggy back ecu (apexi i think)
Anyway with all the gauges connected i can disconnect the TPS, unplug the vacuum line from the manifold, and by applying suction, and releasing i can get my vvt light to come on and go off, all in my driveway. I know that this may not be very scientific, but it works. And no the piggyback is not taking over, as i can still do this when i disconnect it, and yes the engine does run like a pig, but it was to check vvt not anything else.
Mr Revhead wrote:
and not ruined due to another fault
