3sgte boost cut controler
Postby frogg » Fri Jun 01, 2007 7:51 am
i have a gready boost cut controller i had it on my old mr2 then took it off wen i sold it now i have a new mr2 and i cnt member how it wired up so if any1 can help me that wud b great
frogg
Postby AJz » Fri Jun 01, 2007 7:48 pm
i take no responsibility for telling you this but there should be a solenoid that comes off the intake manifold, it has a green plug attached to it. Unplugging this will remove the cut. As i said, if you make your engine go boom, its your own fault. If you get a me a pic i cant point it out to you.
I had vtax :(
AJz
Postby fivebob » Fri Jun 01, 2007 7:54 pm
AJz wrote:i take no responsibility for telling you this but there should be a solenoid that comes off the intake manifold, it has a green plug attached to it. Unplugging this will remove the cut. As i said, if you make your engine go boom, its your own fault. If you get a me a pic i cant point it out to you.
Um, what green plug? The VSV is the only green plug I can think of, and unplugging that will result in the boost being limited to approx 7PSI if it's still connected.
There is no way that unplugging any electronic component on a stock MR2 will stop boost cut.
Postby sergei » Fri Jun 01, 2007 8:23 pm
if it has AFM, then you can unplug "Turbo Boost Sensor" which should be somewhere on the firewall (if I am not mistaken) or bootwall on MR2s.
GO here for full explanation how to do it. You do not need fancy FCD.
http://www.gtfours.co.uk/how_to/fcd/fcd.htm
Postby fivebob » Fri Jun 01, 2007 8:32 pm
sergei wrote:if it has AFM, then you can unplug "Turbo Boost Sensor" which should be somewhere on the firewall (if I am not mistaken) or bootwall on MR2s.
By unplug I assume you mean to disconnect and plug the hose coming from the manifold. Disconnecting the MAP sensor electrical connection will cause a check engine light and limp mode.
Postby AJz » Fri Jun 01, 2007 10:06 pm
yes sorry thats what i ment, will only work on afm'd 3sgte.
I had vtax :(
AJz
Postby sergei » Sat Jun 02, 2007 12:12 am
Yeah, or unplug it and put a resistor across.
